I get the following Errormessage:
++ MbedOS Error Info ++
Error Value: 0x0
Current Thread: main Id: 0x20001E20 Entry: 0x8006875 StackSize: 0x1000 StackMem: 0x20000450 SP: 0x2000138C
– MbedOS Error Info –
This board does not have a hardware USB driver
I’m sorry, I copied and wrote the wrong template above.
The USBDEVICE is from device_has so in the mbed_app.json must be device_has_add and not commponent_add.
Tested with Nucleo-L152RE, MbedOS 6.15.1 and Online compiler and it is working (DTR signal ON in PC terminal app).
Another possible reason of your crash can be Keil Studio online, if you use it. It seems like it ignores mbed_app.json configuration sometimes. I tried same code with Keil Studio and result is the crash.
KeilStudio should trigger clean build with every change in mbed_app.json, but it doesn’t behave that way.
