The collector and base of the NPN transistor MMBT3904LT1G are connected to the diode pin of the LM5066. The emitter is connected to the ground. The board was placed in a -20°C thermal chamber. We received data as 0xF0Ah while reading the local temperature register 0x8Dh. How to make the data negative in temperature. Data from the LM5066 was received correctly as 0x190h at room temperature +25.
Related topics
| Topic | Replies | Views | Activity | |
| Connecting Mbed lpc1768 to temperature senor LM61 along with external LEDs | 3 | 960 | November 29, 2021 | |
| Incorrect voltage readings from LM35 and STM32 (blue pill) | 1 | 765 | February 16, 2021 | |
| How can I read MAX30205 temperature sensor values bulit in MAX32620HSP board? | 0 | 505 | April 21, 2020 | |
| Custom F446RE board fails with both reads and writes to I2C | 9 | 279 | January 9, 2024 | |
| Output from DHT22 | 4 | 883 | April 10, 2022 |
