As the name says, I am facing problem in the given command. The problem is that there is no member named key in MFRC522 library. Here is the error
" No member named ‘key’ in ‘MFRC522’ "
I need help resolving it…
same like in your pervious topic
- what a library?
- from where this error come from?
- What a build tool do you use?
- which MbedOs version do you use?
The key is a parametr of function uint8_t MFRC522::PCD_Authenticate(uint8_t command, uint8_t blockAddr, MIFARE_Key *key, Uid *uid)
