Read me first: About the Electronics and hardware category
Welcome to the electronics and hardware category. You can use this category to discuss boards, components and modules used for embedded and IoT development. Posts here are monitored by our support team, our partners and the community.
For the quickest, most relevant response please tag your post as clearly as possible. If you are discussing a specific board add a tag for the manufacturer (NXP, ST, Rhombio etc.) and you will then be able to find a list of specific boards. There is a tag for every board currently listed on Development boards | Mbed. If you can’t find your board just tag with the manufacturer/vendor name.
You should also include the name of your board, module or component in the title of your post.
Be as specific as you can with your questions, tell us what you’ve tried already, what’s happened, what IDE you’re using etc. The more information you provide the more likely you are to get the answer you need.
If you’re adding a code example please use preformatted text (available in the editor).
If possible, providing the waveform for hardware issues would be helpful!
