I have a data file: data.txt
I run the following:
rsa_genkey
creates: rsa_priv.txt and rsa_pub.txt as expected
rsa_sign data.txt
creates: data.txt.sig as expected, using rsa_priv.txt
rsa_verify data.txt
verifies data.txt and data.txt.sig using rsa_pub.txt as expected
I need to sign data with a private key using mbedtls in my app and send the data and sig
to a server for verification with the public key using php’s openssl_verify.
(The data and sig will be sent over an https connection.)
So I created a key pair using:
openssl genpkey -algorithm RSA -out private_key.pem -pkeyopt rsa_keygen_bits:2048
I extracted the public key using:
openssl rsa -pubout -in private_key.pem -out public_key.pem
Now I need a utility based on rsa_sign.c which will read private_key.pem and sign
data.
I’ve found: mbedtls_x509_crt_parse so I can read the pem to a buffer and load
it into a mbedtls_x509_crt structure.
I can not find how to create an mbedtls_rsa_context structure from the
mbedtls_x509_crt structure so I can use it to sign the data.
I’ve been programming for almost 30 years but I’m new to Cryptography.
If the certificate I generated is even the right one for rsa signing I’m not
even sure of.
I need a code sample and at what point in rsa_sign.c my new structure
(based on the .pem cert) is useful.
Thanks in advance.
ScottB
