I’m attempting to do what is a relatively common task: use a bit of my STM32L476RG’s flash as user data storage to persist a configuration across reboots of the device. I’m following what is described at microcontroller - Allocating memory in Flash for user data (STM32F4 HAL) - Stack Overflow for the linker setup and the Mbed OS documentation for FlashIAP.
I’ve got a custom linker file that includes the following:
MEMORY
FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 0x100000 - 128k
DATA (rwx) : ORIGIN = 0x080E0000, LENGTH = 128k
SRAM2 (rwx) : ORIGIN = 0x10000000 + (((98 * 4) + 7) & 0xFFFFFFF8), LENGTH = 0x8000 - (((98 * 4) + 7) & 0xFFFFFFF8)
SRAM1 (rwx) : ORIGIN = 0x20000000, LENGTH = 0x18000
.user_data :
. = ALIGN(8);
*(.user_data)
. = ALIGN(8);
} > DATA
In my code I have a couple of defines for the start of the user data and the size, as well as a static variable that points to that location in flash:
#define FLASH_USER_DATA_START 0x080E0000
#define FLASH_USER_DATA_SIZE 0x20000 // 128k
static uint8_t userConfig[64] __attribute__((__section__(".user_data")));
static const char *testBuffer = "Hello";
My code to store the data is:
void MFConfiguration::Save()
auto flash = new FlashIAP();
flash->init();
flash->erase(FLASH_USER_DATA_START, FLASH_USER_DATA_SIZE);
flash->program(testBuffer, FLASH_USER_DATA_START, 8);
flash->deinit();
If I step through this in the debugger the erase step works correctly (userConfig becomes all 0xff as expected) and after the program step I see Hello in userConfig.
However when I re-run the app under the debugger, userConfig is 0x00 ![]()
Anyone have any tips for what I might be missing? Thanks!
