I’m using an STM32L475 (DISCO L475VG IoT board), Mbed OS 6, and an SPI SD card reader breakout board. Below is my code, it’s a simplified and slightly modified version of the example code linked in the header. I want the uC to append whatever printf phrase I assign it to the end of the text file on the SD card, such that when the system is powered off and on it will always add new data rather than overwrite old data. In the use case of the final product we are developing, the system will frequently be powered cycled and have new, different data to add to the text log.
Currently, it seems to overwrite part or all of the previous data depending on the length of the new test phrase. Is there something I’m missing with my implementation here?
/* Mbed Hardware Test
Authors: Jackie Hanlon, Conner Reinholt
SD Card code based on: https://os.mbed.com/users/hudakz/code/SDCard/
#include <stdio.h>
#include "SDBlockDevice.h"
#include <errno.h>
#include "FATFileSystem.h"
// Physical block device, can be any device that supports the BlockDevice API
SDBlockDevice blockDevice(PA_7, PA_6, PA_5, PA_2); // mosi, miso, sck, cs
// File system declaration
FATFileSystem fileSystem("fs");
// Entry point for the example
// Try to mount the filesystem
fflush(stdout);
int err = fileSystem.mount(&blockDevice);
if (err) {
printf("Failed to recognize SD card\n");
return 0;
// Open file
FILE *f = fopen("/fs/peanut.txt", "r+");
if (!f) {
printf("No file found, creating a new file... ");
fflush(stdout);
f = fopen("/fs/peanut.txt", "a");
fprintf(f, "just another test thing\n");
fclose(f); // Close the file which also flushes any cached writes
// Tidy up
fflush(stdout);
fileSystem.unmount(); //unmount device
fflush(stdout);
blockDevice.init();
fflush(stdout);
blockDevice.erase(0, blockDevice.size()); //erase block device
fflush(stdout);
blockDevice.deinit(); //deinitialize block device
printf("\n");
