my friend and i have written a program for a LED game which starts if certain conditions are met by the color and distance sensor. we have to interface this game with the help of visual studio, windows forms using serial ports… i want to edit my code in such a way that when i press the close button on windows forms, the game stops and remains halted till i give it the command to start again. the code on mbed is shown below
#include "DebounceIn.h"
#include "stdint.h"
#include "MCP23017.h"
#include "WattBob_TextLCD.h"
#include "VL6180.h"
#include "TCS3472_I2C.h"
#define BACK_LIGHT_ON(INTERFACE) INTERFACE->write_bit(1,BL_BIT)
#define BACK_LIGHT_OFF(INTERFACE) INTERFACE->write_bit(0,BL_BIT)
MCP23017 *par_port;
WattBob_TextLCD *lcd;
#define IDENTIFICATIONMODEL_ID 0x0000
Serial PC(USBTX, USBRX); //default 9600 baud
VL6180 TOF_sensor(p28, p27);
TCS3472_I2C rgb_sensor(p9, p10);
DigitalOut myled1 (p13); DigitalOut myled2 (p14);
DigitalOut myled3 (p15); DigitalOut myled4 (p16);
DebounceIn pb1(p17); DebounceIn pb2(p18);
DebounceIn pb3(p19); DebounceIn pb4(p20);
int old_pb1 = 0, old_pb2 = 0, old_pb3 = 0, old_pb4 = 0;
int new_pb1, new_pb2, new_pb3, new_pb4;
int i = 0, col, row, led; //variables for order manipulation
int levelreset, tries, level = 1; //level parameters
float delay; //delay for blinking LEDs
int D = 30; //for distance sensor
int order[24][4] = //ORDER ARRAY FOR LED GAME
{1,2,3,4, 2,1,3,4, 3,1,2,4, 1,3,2,4, 2,3,1,4, 3,2,1,4,
4,2,1,3, 2,4,1,3, 1,4,2,3, 4,1,2,3, 2,1,4,3, 1,2,4,3,
1,3,4,2, 3,1,4,2, 4,1,3,2, 1,4,3,2, 3,4,1,2, 4,3,1,2,
4,3,2,1, 3,4,2,1, 2,4,3,1, 4,2,3,1, 3,2,4,1, 2,3,4,1};
void LEDgame(); //function prototype of LED game
void reset(); //to reset level
void light(int); //turn on LEDs
void Maint(); // maintainence mode
int Dist(); //check distance sensor
int MAX(int,int,int); //find max rgb value
pb1.mode(PullUp); pb2.mode(PullUp);
pb3.mode(PullUp); pb4.mode(PullUp);
wait(.001);
par_port = new MCP23017(p9, p10, 0x40);
par_port->config(0x0F00, 0x0F00, 0x0F00); //configure MCP23017 chip on WattBob
lcd = new WattBob_TextLCD(par_port);
BACK_LIGHT_ON(par_port);
TOF_sensor.VL6180_Init();
rgb_sensor.enablePowerAndRGBC();
rgb_sensor.setIntegrationTime(100);
int rgb_read[4], maxrgb;
char c = PC.getc();
if (c == 'o'){
while(1)
rgb_sensor.getAllColors(rgb_read);
maxrgb = MAX(rgb_read[1],rgb_read[2],rgb_read[3]);
if (maxrgb == rgb_read[1])
//if (maxrgb > 2000 && maxrgb < 3000)
while(level <= 4 && Dist() < D)
if (level == 0) break; //to stop game if level reset to zero.
row = rand()%24;
tries = 1;
LEDgame();
if (Dist() > D) {
level = 1;
myled1=0; myled2=0; myled3=0; myled4=0;
} //resets game if card is removed.
void LEDgame()
while(Dist() < D)
levelreset = 0;
for (col=0; col<4; col++)
{led = order[row][col]; light(led);} //switches on the respective LEDs according to the order
while(Dist() < D)
new_pb1 = pb1; new_pb2 = pb2;
new_pb3 = pb3; new_pb4 = pb4;
if( ((new_pb1 == 0) && (old_pb1 == 1)) || ((new_pb2 == 0) && (old_pb2 == 1)) || ((new_pb3 == 0) && (old_pb3 == 1)) || ((new_pb4 == 0) && (old_pb4 == 1)) )
switch(order[row][i])
case 1:
if((new_pb1 == 0) && (old_pb1 == 1))
{ myled1 = 1; i++;}
else {reset(); levelreset = 1; tries++;}
} break;
case 2:
if((new_pb2 == 0) && (old_pb2 == 1))
{ myled2 = 1; i++;}
} break;
case 3:
if((new_pb3 == 0) && (old_pb3 == 1))
{ myled3 = 1; i++;}
} break;
case 4:
if((new_pb4 == 0) && (old_pb4 == 1))
{ myled4 = 1; i++;}
} break;
if (levelreset == 1) //do if the level was reset during the game
//reset level to zero to stop game if number of tries exceeded
if (tries > 3) {level = 0; reset(); return;}
else break;
else if (levelreset == 0) //else increment level counter
if(i >= 4){level++; wait(2); reset(); return;}
old_pb1 = new_pb1; old_pb2 = new_pb2;
old_pb3 = new_pb3; old_pb4 = new_pb4;
void reset() //function to turn off LEDs and reset order
myled1 = 0; myled2 = 0; myled3 = 0; myled4 = 0;
i = 0; wait(1); return;
void light(int n) //to turn on LEDs
//sets delay based on level number
if(level == 1) delay = 1;
else if (level == 2) delay = 0.75;
else if (level == 3) delay = 0.50;
else if (level == 4) delay = 0.25;
//turns LED on for delay seconds before turning off
if(n == 1) {myled1 = 1; wait(delay); myled1 = 0;}
else if(n == 2) {myled2 = 1; wait(delay); myled2 = 0;}
else if(n == 3) {myled3 = 1; wait(delay); myled3 = 0;}
else if(n == 4) {myled4 = 1; wait(delay); myled4 = 0;}
return;
int Dist() //returns distance
uint8_t dist;
lcd->cls(); lcd->locate(0,0);
dist = TOF_sensor.getDistance();
lcd->printf("Dist=%d", dist);
return dist;
int MAX(int R, int G, int B) //returns max rgb value
int max;
if (R > G) max = R;
else max = G;
if (B > max) max = B;
return max;
