Overview
I’m attempting to use mbedtls within a project to hash an ECC public key using sha256, and then base58 encode it. I’m running into an issue were about 25% of the time the output from mbedtls_sha256_ret is not always 32 bytes.
I’ve observed the output be anything from 0 bytes, up to 38 bytes. While researching the issue I found this thread from the old forums. I tried the suggestions, and made sure to avoid using strlen however the issue still remains.
For example here is the following output
public key length: 178 <-- expected
public key hash length: 32 <-- expected
digest length: 32 <-- exepected
multihash buffer length: 34 ,-- expected
QmXTUk1HEGdrtiigAyMBqUzF2B9YzWSp8FYfZvp6Dfpq6F <-- expected
Now running the same test suite again a few more times, and I get this
public key hash length: 27 <-- UNEXPECTED - sha256 output is 27 bytes as opposed to 32
digest length: 27 <-- UNEXPECTED
multihash buffer length: 29 <-- UNEXPECTED
pgWvTzePQ6Ge5JUaqJQfDNeM91F93oxP9yZZs1Q <-- UNEXPECTED
- Here is the CMocka test that is being problematic
- Here is the function that is responsible for doing the hasing
- Here is the call to the hash function which occasionally returns bad output
Version Information
- gcc:
gcc (Ubuntu 9.3.0-10ubuntu2) 9.3.0 - mbedtls:
v2.23.0 - os kernel:
Linux gray 5.4.0-7634-generic #38~1592497129~20.04~9a1ea2e-Ubuntu SMP Fri Jun 19 22:43:37 UTC x86_64 x86_64 x86_64 GNU/Linux
/etc/lsb-release:
DISTRIB_ID=Pop
DISTRIB_RELEASE=20.04
DISTRIB_CODENAME=focal
DISTRIB_DESCRIPTION="Pop!_OS 20.04 LTS"
