Hello, I am having troubles with computing the sha256 using mbedtls functions. I’ll try to explain the problem the best as I can:
I have two memory segments, let’s call them A and B. In segment A I have stored all the
mbedtls functions, but now I need to call theese functions from B, and in particular I need to
compute the sha256 of a certain string. For this purpose I have made a test calling the starts, update and finish functions as follows:
//Segment B
int ret = 0;
char* data = “123456789”;
uint8_t hash[32] = {0};
mbedtls_sha256_context ctx;ret = mbedtls_sha256_starts_ret( &ctx, 0 );
ret = mbedtls_sha256_update_ret( &ctx, data, 9 );
ret = mbedtls_sha256_finish_ret( &ctx, hash );
The result contained in hash is completely different from what it should be.
I have tried to do the same thing in segment A and the result is correct instead. So I was doing some debugging just to understand what was going wrong in segment B, and I discovered that the contex ctx is initialized and updated properly, but at some point in the finish it happens that something different is written in the state[] part of the context (the rest is exactly the same as in segment A), and I don’t understand why. It seems that something wrong happens into the mbedtls_internal_sha256_process() function, but I don’t know what to do to fix that. Any suggestions?
Thank you very much in advance.
