Board: NUCLEO-H743ZI2.
I want to use sigio for tracking TCPSocket state by nsapi_error codes.
I’m not familiar with sigio and how to use it with mbed.
I read #3620 and #11025.
I try to do someting like this:
Code
#include "EthernetInterface.h"
#include "nsapi_types.h"
static constexpr char IP_ADDR[] = "192.168.088.254";
static constexpr uint16_t PORT = 3333;
EthernetInterface net;
SocketAddress a;
TCPSocket socket;
nsapi_size_or_error_t socket_response;
Mutex print_mutex;
char socket_buffer[250] = {};
void safe_print(const char *msg /*format*/, ...);
void status_callback(nsapi_event_t status, intptr_t param);
void tcp_handler();
nsapi_error_t socket_connect, socket_open;
socket.sigio(&tcp_handler);
net.add_event_listener(&status_callback);
safe_print("connecting...\r\n");
net.connect();
safe_print("Connecting started...\r\n");
net.get_ip_address(&a);
printf("IP address: %s\n", a.get_ip_address() ? a.get_ip_address() : "None");
socket_open = socket.open(&net);
safe_print("socket_open: %d\n",socket_open);
net.gethostbyname(IP_ADDR, &a);
a.set_port(PORT);
socket_connect = socket.connect(a);
safe_print("socket_connect: %d\n\r", socket_connect);
while(true)
socket.close();
net.disconnect();
return 0;
print_mutex.lock();
printf(msg);
print_mutex.unlock();
safe_print("Connection status changed!\r\n");
switch (param) {
case NSAPI_STATUS_LOCAL_UP:
safe_print("Local IP address set!\r\n");
break;
case NSAPI_STATUS_GLOBAL_UP:
safe_print("Global IP address set!\r\n");
break;
case NSAPI_STATUS_DISCONNECTED:
safe_print("No connection to network!\r\n");
break;
case NSAPI_STATUS_CONNECTING:
safe_print("Connecting to network!\r\n");
break;
default:
safe_print("Not supported\r\n");
break;
void tcp_handler()
printf("sigio called\n");
socket_response = socket.recv(socket_buffer, sizeof socket_buffer);
printf("%d\n",socket_response);
if (socket_response == NSAPI_ERROR_WOULD_BLOCK) {
safe_print("Would_Block\n\r");
} else if (socket_response < 0) {
safe_print("%d\n\r", socket_response);
} else if (socket_response == 0) {
safe_print("=0\n\r");
tcp_handler called after socket_open and then all freezes.
Here my serial output:
connecting...
IP address: 192.168.88.253
socket_open: 0
sigio called
Can anyone explain me how to use sigio correctly? Or using sigio in my case is wrong?
