I’m trying to use the SPI transfer function to perform non-blocking SPI transactions on an NUCLEO-F303K8 (STM32F303K8) board but the function appears to be blocking. I started with the bare-metal profile and my SPI instance is a member of a class. The following code snippet is how I’m using it:
//SPI init
SPI mySpi(MOSI, NC, SCK, NC) //don't need MISO
mySpi.format(8);
mySpi.frequency(8000000);
//usage later in function
gpio_write(&test_pin,1);
mySpi.transfer(&TxBits, sizeof(TxBits), &RxBits, 0, event_callback_t(this, &myClass::SPI_Complete), SPI_EVENT_COMPLETE);
gpio_write(&test_pin,0);
I2C_Transaction();
The transfer is blocking, as shown below, the gpio pin stays high the entire transaction, where it should go low at some time near the start of the SPI data. The I2C transaction should also occur during the SPI transaction.
As a double whammy, not only is it blocking, there is a lot of downtime between byte transmissions. One byte takes 1us, and there is nearly 3us between bytes. A normal SPI write call (blocking) only has 500ns between bytes.
I hope I’m missing something, any help is appreciated!
