Hello Lane,
The crystal is present, close to the chip, and pretty much copied from the nucleo board schematic.
My NUCLEO-F767ZI might be different than yours but this is what it is equipped with:
Crystal Frequency Puspose Present on board
X1 8 MHz ST-LINK/V2-1 Yes
X2 32.768 kHz Real Time Clock Yes
X3 8 MHz Main Clock No
X4 25 Mhz Ethernet Phy Yes
As you can see my board is not equipped with an 8 MHz crystal for the main clock. This is consistent with the info in the user manual which says that the default source of HSE is the MCO from the ST-Link programmer and that the HSE on-board oscillator from X3 crystal is not provided:
6.8.1 OSC clock supply
There are four ways to configure the pins corresponding to the external high-speed clock
(HSE):
- MCO from ST-LINK (Default): MCO output of ST-LINK is used as input clock. This
frequency cannot be changed, it is fixed at 8MHz and connected to the
PF0/PH0-OSC_IN of STM32 microcontroller. The configuration must be:
– SB148 OFF
– SB112 and SB149 ON
– SB8 and SB9 OFF
- HSE on-board oscillator from X3 crystal (not provided): for typical frequencies and
its capacitors and resistors, refer to the STM32 microcontroller datasheet and to the
Oscillator design guide for STM8S, STM8A and STM32 microcontrollers Application
note (AN2867) for the oscillator design guide. The X3 crystal has the following
characteristics: 8MHz, 8pF, 20ppm. It is recommended to use NX3225GD-8.000M-
EXS00A-CG04874 manufactured by NIHON DEMPA KOGYO CO., LTD. The
– SB148 and SB163 OFF
– SB8 and SB9 soldered
– C37 and C38 soldered with 4.3pF capacitors
– SB112 and SB149 OFF
- Oscillator from external PF0/PH0: from an external oscillator through the pin 29 of
the CN11 connector. The configuration must be:
–SB148 ON
–SB112 and SB149 OFF
–SB8 and SB9 removed
- HSE not used: PF0/PH1 and PF1/PH1 are used as GPIOs instead of as clock. The
– SB148 and SB163 ON
– SB112 and SB149 (MCO) OFF
– SB8 and SB9 removed
If your board is equipped with an 8 MHz HSE crystal for the main clock then make sure the configuration is set accordingly (the solder bridges SB148, SB163, SB8, SB9, SB112 an SB149 should be configured as indicated above).
With best regards, Zoltan
