Hiya,
When selecting a board in the compiler and for example loading a simple blinky program, is the board using the internal oscillator HSI or the external oscillator HSE?
Hiya,
Hello Muhammed,
By default, NUCLEO boards use the HSE clock signal coming from the STLink programmer/debugger attached to the board.
For any target board you can find the related info in the https://github.com/ARMmbed/mbed-os/blob/master/targets/targets.json file:
"clock_source": {
"help": "Mask value : USE_PLL_HSE_EXTC | USE_PLL_HSE_XTAL (need HW patch) | USE_PLL_HSI",
"value": "USE_PLL_HSE_EXTC|USE_PLL_HSI",
"macro_name": "CLOCK_SOURCE"
Best regards, Zoltan
