While attempting to update the Mbed OS version used by our application I started seeing crashes.
This led me to investigate the RTC tickless behaviour and question what the configuration should be.
I’ve discussed this configuration in the past a great deal with @jeromecoutant.
I have a very simple demonstration that will not run reliably on my NUCLEO-L433RC-P…
#include <Kernel.h>
#include <ThisThread.h>
#include <cstdio>
printf("tickless RTC V5.14.1\n");
while (1) {
rtos::ThisThread::sleep_for(3000);
printf("get_ms_count %llu\n", rtos::Kernel::get_ms_count());
Importantly the RTC is selected for the LPTICKER:
"target_overrides": {
"platform.stdio-baud-rate": "115200",
"target.lpticker_lptim": 0
If I build with Mbed V.5.14.1 this app will not run for long. Sometimes it freezes after a just a few iterations, sometimes it runs for a minute or 2.
If I build with Mbed V5.13.4 this app runs continually. Of course it is difficult to guarantee the absence of a problem but I’ve run the V5.13.4 version considerably longer without seeing it freeze.
Adding "target.lpticker_delay_ticks": 1 appears to make the V5.14.1 build stable but I’m reluctant to change an important setting like this without discussion! It seems a bit odd that updating Mbed OS requires a change to a setting like this.
To summarise my question, what’s the recommended RTC tickless configuration for STM32L4 and Mbed OS V5.14 or later?
I’m compiling this test using the online compiler which I guess is the ARM compiler. But, I believe I see the same issue building offline with ARM GCC.
I know there have been some significant changes relating to sleep, e.g. Sleep rework, RTOS API for bare metal, wait deprecations #10104, which partly why I wanted to update Mbed OS. But clearly, I can’t update if it breaks my app!
Matt
