A HAL_RCC_OscConfig problem in mbed-os 6.12
I had remove the extern XTAL from the NCULEO-L432KC.
And below is my mbed_app.json (To use internal 16MHz XTAL):
    "target_overrides": {
        "NUCLEO_L432KC": {
            "target.clock_source": "USE_PLL_HSI"
mbed-os 5.14 : work fine.
mbed-os 6.12 : show a run-time error as below:
++ MbedOS Error Info ++
Error Value: 0x0
Current Thread: <unnamed> Id: 0x0 Entry: 0x8000299 StackSize: 0x0 StackMem: 0x8000325 SP: 0x2000FE4C
For more info, visit: https://mbed.com/s/error?error=0x80FF0100&tgt=NUCLEO_L432KC
-- MbedOS Error Info --
HAL_RCC_OscConfig ERROR
Sorry, I need help …
Best Regards,
Jason
I got a solution .
If disable the tickless feature, the internal XTAL will work fine.
"target.macros_remove": ["MBED_TICKLESS"]
Also have to remove all platform stats features from mbed_app.json:
  "platform.stack-stats-enabled*": true,
  "platform.heap-stats-enabled*": true,
  "platform.cpu-stats-enabled": true,
  "platform.thread-stats-enabled": true,
  "platform.sys-stats-enabled": true,
Is a bug in the mbed-os 6.12 ?
