I trying to compile project:
https://github.com/ARM-software/ML-KWS-for-MCU/tree/master/Deployment , which was created by mbed. I worked with kws_realtime_test project for STM32F746NG board. I m trying to compile on Ubuntu machine in command line.
I made step by step everything by the attached README.md file, from an above mentioned project.
When I call mbed deploy, than I get a warning message:
[mbed] WARNING: Cannot find the mbed tools directory in “/home/alessandro/Scrivania/ML_KWS/Deployment/kws_realtime_test”
And when I try to compile than I get an error:
[mbed] ERROR: The mbed tools were not found in “/home/alessandro/Scrivania/ML_KWS/Deployment/kws_realtime_test”
You can run “mbed deploy” to install dependencies and tools.
On some forum I read, that I need to add mbed-os to my project
Link: https://os.mbed.com/questions/81212/warning-The-mbed-tools-were-not-found-in/
When I add that, I can deploy the project without any warning, but I have an error after compile:
Include
[ERROR] Library name ‘platform’ is not unique (defined in ‘“/home/alessandro/Scrivania/ML_KWS/Deployment/kws_realtime_test\mbed\65be27845400\TARGET_DISCO_F746NG\TOOLCHAIN_GCC_ARM\mbed_lib.json’ and “/home/alessandro/Scrivania/ML_KWS/Deployment/kws_realtime_test\mbed-os\platform\mbed_lib.json’)
[mbed] Working path “”
I tried to remove one of .json files, and the compilation finally can start, but after 10% I get many compiler errors. My compiler cant compile source files from mbed-os directory. Im using GNU GCC compiler.
- So how can I compile that project?
- Why I need mbed-os to my project? It is not mentioned in readme file. Is it not enough to install mbed-tools, and no whole mbed-os? I think my project do not use any OS functionality.
I 'm working on a compilation of a simple project few days, and is going to be a really nightmare for me.
Are there any simpler way to precompile this project?
I have already seen at https://forums.mbed.com/t/cannot-find-the-mbed-tools-directory/9314/2 but the solution proposed not solve my problem
