Dear ARM mbedTLS Team,
I am encountering an issue with mbedTLS v2.16.2 integrated into STM32CubeIDE while trying to establish a secure MQTT connection to the Mosquitto broker on port 8883. Despite following the recommended setup, the TLS handshake fails with the following error:
mbedtls_ssl_handshake failed. -29312 (-0x7280)
Setup Details:
- Microcontroller: STM32F407
- mbedTLS Version: 2.16.2 (as integrated with STM32CubeIDE)
- Connection Type: PPPoS connection established using a SIM7600 modem
- Broker: Mosquitto broker with TLS enabled on port 8883
- Root Certificate: Using
mosquitto.org.crtas the root certificate
Steps Taken:
- Configured mbedTLS for secure MQTT communication.
- Provided the root CA certificate (
mosquitto.org.crt). - Successfully established the PPPoS connection using the SIM7600 modem.
Issue:
When attempting to establish the secure MQTT connection, the TLS handshake fails with the error code -29312 (-0x7280). This error seems to indicate an issue with the handshake process, possibly related to an invalid MAC or other TLS configuration issues.
Request:
- Could you confirm whether mbedTLS v2.16.2, as provided in STM32CubeIDE, fully supports secure MQTT connections in this context?
- Are there any known limitations or additional configurations required to use mbedTLS for this purpose?
- Guidance on resolving this issue would be highly appreciated.
Please let me know if you require further details, such as configuration settings or log outputs.
Thank you for your assistance.
