I’ve been trying to establish a secured TLS connection to a remote host using Nucleo-L432KC platform but to no avail. I have tested my code with Nucleo-L476RG and it works great. Did some research, although I’m not sure, it seems that the insufficient available RAM is the issue.
regarding mbed TLS RAM usage, I found the following post:
and following Wikipedia article (Mbed OS uses same implementation?):
In the official documentation of Mbed OS, there is no mention of recommended or minimal required RAM and flash size for TLSSocket.
This is my code:
* Copyright (c) 2006-2020 Arm Limited and affiliates.
*Code by: Danial Mousavi
/**@Introduction:
*In this version of the example, we will use the mbed-mqtt library to establish a secured connection to a MQTT broker (server)
#include "MQTTClient.h"
#include "MQTTConnect.h"
#include "ESP8266Interface.h"
#include <MQTTClientMbedOs.h>
#include <cstdint>
#include <cstdio>
/**@NOTES!
* The MOD-WiFi-ESP8266 is tested only on K64F, NUCLEO-L432KC and NUCLEO-L476RG * platforms by the author. There are few technical mysteries and issues that * have been encountered by author. Some noteable ones are:
* - This WiFi module only works with UART1 on pins D8(PA_9) and D2(PA_10) on * NUCLEO-L476RG, without any changes to PeripheralPins.C
* - NUCLEO-L432KC cannot establish TLS connection for whatever reason.
* Problem lays on socket level.
ESP8266Interface wifi(D1, D0); //Creat a WiFi interface
// here you add the CA certificate in chain PEM format. The following PEM formatted Root Chain Certificate is from test.mosquitto.org (August, 2022)
const char cert[] ="-----BEGIN CERTIFICATE-----\n"
"MIIFPzCCBCegAwIBAgISBLoxKrvgo1IWjviQTuwWeXGAMA0GCSqGSIb3DQEBCwUA\n"
"MDIxCzAJBgNVBAYTAlVTMRYwFAYDVQQKEw1MZXQncyBFbmNyeXB0MQswCQYDVQQD\n"
"EwJSMzAeFw0yMjA1MjQwMzU4NDBaFw0yMjA4MjIwMzU4MzlaMB0xGzAZBgNVBAMT\n"
"EnRlc3QubW9zcXVpdHRvLm9yZzCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoC\n"
"ggEBAMVlQixUbp36iRUw1KRGehqqzOA/fqjvYQ/htyherIwrCKMZt6AoDaXTvd8K\n"
"hwOfKr6V71MXWqq+7sq95FhcMJQXS6jMtrxSqUrhvyXtWcnJe9zN2/C6+CvwamOP\n"
"cyHHRY8FNakOIs6G8WsdhHxu7D3CtZYJp2a7UhFBo/UdO1kvJGW2ReU0CZWtBZCg\n"
"wHVsDTI/3hhLWeN1ZVHKyYAifRkd39Owj1ZXFbQyrTAFgxaGjwZ8Z0Vtzgg/5CrB\n"
"2z8kBkG25ywEtKWiXVNiju0EaApHK1M34ZXo9fTMu+kNLlvsJVpLn0EaRNCKJgGm\n"
"OJezsEqo3e3/ylH67/EwDNf8NZcCAwEAAaOCAmIwggJeMA4GA1UdDwEB/wQEAwIF\n"
"oDAdBgNVHSUEFjAUBggrBgEFBQcDAQYIKwYBBQUHAwIwDAYDVR0TAQH/BAIwADAd\n"
"BgNVHQ4EFgQUBkhYCbv9JWU7LSA4P4rRZbi+nWAwHwYDVR0jBBgwFoAUFC6zF7dY\n"
"VsuuUAlA5h+vnYsUwsYwVQYIKwYBBQUHAQEESTBHMCEGCCsGAQUFBzABhhVodHRw\n"
"Oi8vcjMuby5sZW5jci5vcmcwIgYIKwYBBQUHMAKGFmh0dHA6Ly9yMy5pLmxlbmNy\n"
"Lm9yZy8wMgYDVR0RBCswKYISdGVzdC5tb3NxdWl0dG8ub3JnghN0ZXN0Ni5tb3Nx\n"
"dWl0dG8ub3JnMEwGA1UdIARFMEMwCAYGZ4EMAQIBMDcGCysGAQQBgt8TAQEBMCgw\n"
"JgYIKwYBBQUHAgEWGmh0dHA6Ly9jcHMubGV0c2VuY3J5cHQub3JnMIIBBAYKKwYB\n"
"BAHWeQIEAgSB9QSB8gDwAHYAKXm+8J45OSHwVnOfY6V35b5XfZxgCvj5TV0mXCVd\n"
"x4QAAAGA9G5z0QAABAMARzBFAiBRtFSyGzj960BhRCsWR6fHHqFDZKEnqZYdOnXd\n"
"pPKnJQIhAJYxSk81MYMm6sPHMHEk1qzLHox7AveNp0+q+no5FVKWAHYAQcjKsd8i\n"
"RkoQxqE6CUKHXk4xixsD6+tLx2jwkGKWBvYAAAGA9G50BAAABAMARzBFAiEAn1oK\n"
"qeze7kcgsvY4ArRDhQYpLBC/eDLdj740XFrswaUCIBPqE7OeMV4whhxB9JTIlfGh\n"
"VjbMEvXYUPv2Vmq8e0saMA0GCSqGSIb3DQEBCwUAA4IBAQB7reTupf23LS0TowCf\n"
"N5VMFXjoBFyvPzTNMlc2+ywIMrNuSz9mCKQIOzXl86l2KodF3chw4H7X1DYY5wZu\n"
"HZoZem8IRZUwIJBA4n93Jd8lMZjZnGSYxWcALfTORK06znDtQFEYm8dUPwEqMGR3\n"
"/ac4YDphqYSw1K3oVslgeXiMJ53CW6v/nB1QPs0Lhd7iFL0jGndeYlclxst1Ybz5\n"
"ntFl1FW0kKVZ7tyoAx2c6cKLgwRof7XzEL+N93fBJIJs4rWhZHuqYoSNxReJ2UIf\n"
"VjJ7rDHrmW46WYPmzQFqIFYepVRAJlqVEaDmUB97yhG3RZgXv9CPN5PFu3+YSq0N\n"
"IyVR\n"
"-----END CERTIFICATE-----\n"
"MIIFFjCCAv6gAwIBAgIRAJErCErPDBinU/bWLiWnX1owDQYJKoZIhvcNAQELBQAw\n"
"TzELMAkGA1UEBhMCVVMxKTAnBgNVBAoTIEludGVybmV0IFNlY3VyaXR5IFJlc2Vh\n"
"cmNoIEdyb3VwMRUwEwYDVQQDEwxJU1JHIFJvb3QgWDEwHhcNMjAwOTA0MDAwMDAw\n"
"WhcNMjUwOTE1MTYwMDAwWjAyMQswCQYDVQQGEwJVUzEWMBQGA1UEChMNTGV0J3Mg\n"
"RW5jcnlwdDELMAkGA1UEAxMCUjMwggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEK\n"
"AoIBAQC7AhUozPaglNMPEuyNVZLD+ILxmaZ6QoinXSaqtSu5xUyxr45r+XXIo9cP\n"
"R5QUVTVXjJ6oojkZ9YI8QqlObvU7wy7bjcCwXPNZOOftz2nwWgsbvsCUJCWH+jdx\n"
"sxPnHKzhm+/b5DtFUkWWqcFTzjTIUu61ru2P3mBw4qVUq7ZtDpelQDRrK9O8Zutm\n"
"NHz6a4uPVymZ+DAXXbpyb/uBxa3Shlg9F8fnCbvxK/eG3MHacV3URuPMrSXBiLxg\n"
"Z3Vms/EY96Jc5lP/Ooi2R6X/ExjqmAl3P51T+c8B5fWmcBcUr2Ok/5mzk53cU6cG\n"
"/kiFHaFpriV1uxPMUgP17VGhi9sVAgMBAAGjggEIMIIBBDAOBgNVHQ8BAf8EBAMC\n"
"AYYwHQYDVR0lBBYwFAYIKwYBBQUHAwIGCCsGAQUFBwMBMBIGA1UdEwEB/wQIMAYB\n"
"Af8CAQAwHQYDVR0OBBYEFBQusxe3WFbLrlAJQOYfr52LFMLGMB8GA1UdIwQYMBaA\n"
"FHm0WeZ7tuXkAXOACIjIGlj26ZtuMDIGCCsGAQUFBwEBBCYwJDAiBggrBgEFBQcw\n"
"AoYWaHR0cDovL3gxLmkubGVuY3Iub3JnLzAnBgNVHR8EIDAeMBygGqAYhhZodHRw\n"
"Oi8veDEuYy5sZW5jci5vcmcvMCIGA1UdIAQbMBkwCAYGZ4EMAQIBMA0GCysGAQQB\n"
"gt8TAQEBMA0GCSqGSIb3DQEBCwUAA4ICAQCFyk5HPqP3hUSFvNVneLKYY611TR6W\n"
"PTNlclQtgaDqw+34IL9fzLdwALduO/ZelN7kIJ+m74uyA+eitRY8kc607TkC53wl\n"
"ikfmZW4/RvTZ8M6UK+5UzhK8jCdLuMGYL6KvzXGRSgi3yLgjewQtCPkIVz6D2QQz\n"
"CkcheAmCJ8MqyJu5zlzyZMjAvnnAT45tRAxekrsu94sQ4egdRCnbWSDtY7kh+BIm\n"
"lJNXoB1lBMEKIq4QDUOXoRgffuDghje1WrG9ML+Hbisq/yFOGwXD9RiX8F6sw6W4\n"
"avAuvDszue5L3sz85K+EC4Y/wFVDNvZo4TYXao6Z0f+lQKc0t8DQYzk1OXVu8rp2\n"
"yJMC6alLbBfODALZvYH7n7do1AZls4I9d1P4jnkDrQoxB3UqQ9hVl3LEKQ73xF1O\n"
"yK5GhDDX8oVfGKF5u+decIsH4YaTw7mP3GFxJSqv3+0lUFJoi5Lc5da149p90Ids\n"
"hCExroL1+7mryIkXPeFM5TgO9r0rvZaBFOvV2z0gp35Z0+L4WPlbuEjN/lxPFin+\n"
"HlUjr8gRsI3qfJOQFy/9rKIJR0Y/8Omwt/8oTWgy1mdeHmmjk7j1nYsvC9JSQ6Zv\n"
"MldlTTKB3zhThV1+XWYp6rjd5JW1zbVWEkLNxE7GJThEUG3szgBVGP7pSWTUTsqX\n"
"nLRbwHOoq7hHwg==\n"
"MIIFYDCCBEigAwIBAgIQQAF3ITfU6UK47naqPGQKtzANBgkqhkiG9w0BAQsFADA/\n"
"MSQwIgYDVQQKExtEaWdpdGFsIFNpZ25hdHVyZSBUcnVzdCBDby4xFzAVBgNVBAMT\n"
"DkRTVCBSb290IENBIFgzMB4XDTIxMDEyMDE5MTQwM1oXDTI0MDkzMDE4MTQwM1ow\n"
"cmNoIEdyb3VwMRUwEwYDVQQDEwxJU1JHIFJvb3QgWDEwggIiMA0GCSqGSIb3DQEB\n"
"AQUAA4ICDwAwggIKAoICAQCt6CRz9BQ385ueK1coHIe+3LffOJCMbjzmV6B493XC\n"
"ov71am72AE8o295ohmxEk7axY/0UEmu/H9LqMZshftEzPLpI9d1537O4/xLxIZpL\n"
"wYqGcWlKZmZsj348cL+tKSIG8+TA5oCu4kuPt5l+lAOf00eXfJlII1PoOK5PCm+D\n"
"LtFJV4yAdLbaL9A4jXsDcCEbdfIwPPqPrt3aY6vrFk/CjhFLfs8L6P+1dy70sntK\n"
"4EwSJQxwjQMpoOFTJOwT2e4ZvxCzSow/iaNhUd6shweU9GNx7C7ib1uYgeGJXDR5\n"
"bHbvO5BieebbpJovJsXQEOEO3tkQjhb7t/eo98flAgeYjzYIlefiN5YNNnWe+w5y\n"
"sR2bvAP5SQXYgd0FtCrWQemsAXaVCg/Y39W9Eh81LygXbNKYwagJZHduRze6zqxZ\n"
"Xmidf3LWicUGQSk+WT7dJvUkyRGnWqNMQB9GoZm1pzpRboY7nn1ypxIFeFntPlF4\n"
"FQsDj43QLwWyPntKHEtzBRL8xurgUBN8Q5N0s8p0544fAQjQMNRbcTa0B7rBMDBc\n"
"SLeCO5imfWCKoqMpgsy6vYMEG6KDA0Gh1gXxG8K28Kh8hjtGqEgqiNx2mna/H2ql\n"
"PRmP6zjzZN7IKw0KKP/32+IVQtQi0Cdd4Xn+GOdwiK1O5tmLOsbdJ1Fu/7xk9TND\n"
"TwIDAQABo4IBRjCCAUIwDwYDVR0TAQH/BAUwAwEB/zAOBgNVHQ8BAf8EBAMCAQYw\n"
"SwYIKwYBBQUHAQEEPzA9MDsGCCsGAQUFBzAChi9odHRwOi8vYXBwcy5pZGVudHJ1\n"
"c3QuY29tL3Jvb3RzL2RzdHJvb3RjYXgzLnA3YzAfBgNVHSMEGDAWgBTEp7Gkeyxx\n"
"+tvhS5B1/8QVYIWJEDBUBgNVHSAETTBLMAgGBmeBDAECATA/BgsrBgEEAYLfEwEB\n"
"ATAwMC4GCCsGAQUFBwIBFiJodHRwOi8vY3BzLnJvb3QteDEubGV0c2VuY3J5cHQu\n"
"b3JnMDwGA1UdHwQ1MDMwMaAvoC2GK2h0dHA6Ly9jcmwuaWRlbnRydXN0LmNvbS9E\n"
"U1RST09UQ0FYM0NSTC5jcmwwHQYDVR0OBBYEFHm0WeZ7tuXkAXOACIjIGlj26Ztu\n"
"MA0GCSqGSIb3DQEBCwUAA4IBAQAKcwBslm7/DlLQrt2M51oGrS+o44+/yQoDFVDC\n"
"5WxCu2+b9LRPwkSICHXM6webFGJueN7sJ7o5XPWioW5WlHAQU7G75K/QosMrAdSW\n"
"9MUgNTP52GE24HGNtLi1qoJFlcDyqSMo59ahy2cI2qBDLKobkx/J3vWraV0T9VuG\n"
"WCLKTVXkcGdtwlfFRjlBz4pYg1htmf5X6DYO8A4jqv2Il9DjXA6USbW1FzXSLr9O\n"
"he8Y4IWS6wY7bCkjCWDcRQJMEhg76fsO3txE+FiYruq9RUWhiF1myv4Q6W+CyBFC\n"
"Dfvp7OOGAN6dEOM4+qR9sdjoSYKEBpsr6GtPAQw4dy753ec5\n"
"-----END CERTIFICATE-----";
const char *sec2str(nsapi_security_t sec)
switch (sec) {
case NSAPI_SECURITY_NONE:
return "None";
case NSAPI_SECURITY_WEP:
return "WEP";
case NSAPI_SECURITY_WPA:
return "WPA";
case NSAPI_SECURITY_WPA2:
return "WPA2";
case NSAPI_SECURITY_WPA_WPA2:
return "WPA/WPA2";
case NSAPI_SECURITY_UNKNOWN:
default:
return "Unknown";
void scan_for_AP(WiFiInterface *wifi)
WiFiAccessPoint *ap;
printf("Scan:\r\n");
int count = wifi->scan(NULL, 0);
/* Limit number of network arbitrary to 15 */
count = count < 15 ? count : 15;
ap = new WiFiAccessPoint[count];
count = wifi->scan(ap, count);
for (int i = 0; i < count; i++) {
printf("Network: %s secured: %s BSSID: %hhX:%hhX:%hhX:%hhx:%hhx:%hhx RSSI: %hhd Ch: %hhd\r\n", ap[i].get_ssid(),
sec2str(ap[i].get_security()), ap[i].get_bssid()[0], ap[i].get_bssid()[1], ap[i].get_bssid()[2],
ap[i].get_bssid()[3], ap[i].get_bssid()[4], ap[i].get_bssid()[5], ap[i].get_rssi(), ap[i].get_channel());
printf("%d networks available.\r\n", count);
delete[] ap;
static void messageArrived(MQTT::MessageData& md)
MQTT::Message &message = md.message;
printf("Message arrived: qos %d, retained %d, dup %d, packetid %d\r\n", message.qos, message.retained, message.dup, message.id);
printf("Payload %.*s\r\n", message.payloadlen, (char*)message.payload);
int connect_to_wlan(SocketAddress &addr){
printf("Searching for WiFi APs\r\n\r\n");
scan_for_AP(&wifi);
printf("\r\nConnecting to local network...\r\n");
int ret = wifi.connect("IoT_Test", "MQTT_TLS_TEST_2022", NSAPI_SECURITY_WPA_WPA2);
if (ret != 0) {
printf("\r\nConnection error\r\n");
return ret;
printf("Success\r\n\r\n");
printf("MAC: %s\r\n", wifi.get_mac_address());
wifi.get_ip_address(&addr);
printf("IP: %s\r\n", addr.get_ip_address());
wifi.get_netmask(&addr);
printf("Netmask: %s\r\n", addr.get_ip_address());
wifi.get_gateway(&addr);
printf("Gateway: %s\r\n", addr.get_ip_address());
printf("RSSI: %d\r\n\r\n", wifi.get_rssi());
/* These are not in use! Feel free to try them though! */
//http_demo(&wifi);
//wifi.disconnect();
printf("\r\nDone\r\n");
return ret;
nsapi_size_or_error_t connect_to_broker(nsapi_size_or_error_t &res, MQTTClient &client, MQTTPacket_connectData data){
if ((res = client.connect(data) != 0)) {
printf("ERROR: did not connect to broker. code: %d\n", res);
return res;
printf("Connected to broker.\n");
return res;
nsapi_size_or_error_t TLSSocket_connect(NetworkInterface *net, TLSSocket *soc, nsapi_size_or_error_t &res, const char* hostname = "test.mosquitto.org", uint16_t port = 8886){
res = soc->set_root_ca_cert(cert);
if (res != 0) {
printf("Error: socket->set_root_ca_cert() returned %d\n", res);
return res;
// ATTACH THE SOCKET TO THE NETWORK INTERFACE (in this case, WiFi)
res = soc->open((*net).wifiInterface());
if (res != 0) {
printf("Error! socket->open() returned: %d\n", res);
return res;
SocketAddress addr;
wifi.gethostbyname(hostname, &addr);
addr.set_port(port);
// CONNECT THE SOCKET TO REMOTE HOST!
printf("Connecting to %s on port %d\n", hostname, port);
res = soc->connect(addr);
if(res != 0) {
printf("Error! socket->connect() returned: %d\n", res);
return res;
else{
printf("Secure connection to the host established!\n");
return res;
//CREAT A SECURE SOCKET
TLSSocket *socket = new TLSSocket;
//buffer for NSAPI error messages
nsapi_size_or_error_t result;
//buffer to store IP address information
SocketAddress a;
MQTTPacket_connectData mqtt_conn_data = MQTTPacket_connectData_initializer;
mqtt_conn_data.MQTTVersion = 3;
mqtt_conn_data.clientID.cstring = "2DOPghqUTR3WT4561UUIG_sdf_23ZQWE";
MQTTClient mqtt_client(socket);
connect_to_wlan(a);
TLSSocket_connect(wifi.wifiInterface(), socket, result);
connect_to_broker(result, mqtt_client, mqtt_conn_data);
MQTT::Message message;
char buf[100];
sprintf(buf, "<!-- WRITE YOUR MESSAGE HERE --!>\r\n");
message.qos = MQTT::QOS0;
message.retained = false;
message.dup = false;
message.payload = (void*)buf;
message.payloadlen = strlen(buf)+1;
//Subscribing to a topic
result = mqtt_client.subscribe("YOUR_TOPIC_HERE", MQTT::QOS0, messageArrived);
if (result != 0) {
printf("Failed to subscribe to the given topic. Error: %d\n", result);
return result;
while(true){
printf("Published a message.\n");
result = mqtt_client.publish("YOUR_TOPIC_HERE", message);
if (result != 0) {
printf("Failed to publish to the given topic. Error: %d\n", result);
mqtt_client.yield(2000); //publish ever 2 second
Is my speculation about insufficient memory usage true? If so, can I somehow reduce the memory footprint? Can I still make it work on Nucleo-L432KC?
Best Regards,
Danial Mousavi
