Unable to connect using TLSSocket and https
I want to open a secure connection to httpbin.org using TLSSocket and then send GET requests.
When using TCPSocket and http, everything works, but when I try the same code with TLS Socket, I get trapped in mbed_die().
Here is the code :
SocketAddress address;
wifi.gethostbyname("httpbin.org", &address);
address.set_port(443);
// TLS socket
TLSSocket *socket = new TLSSocket();
socket->open(&wifi);
socket->set_hostname("httpbin.org");
auto ret = socket->set_root_ca_cert(SSL_CA_CERT);
if (ret != NSAPI_ERROR_OK) {
	log_info("Error when setting root ca cert : %d", ret);
	while (1) ;
ret = socket->connect(address);
	log_info("Error when connecting : %d", ret);
	while (1);
// send GET request ...
In the socket->connect call, the program freezes because of mbed_die().
Here is the trace :
[DBG ][ESPA]: open_udp(): UDP socket 0 opened: true.
[DBG ][ESPA]: _oob_send_ok_received called for socket 0
[DBG ][ESPA]: _oob_socket0_closed(): Socket 0 closed.
[DBG ][ESPA]: close(0): socket close OK with AT+CIPCLOSE OK
[DBG ][TLSW]: mbedtls_ssl_conf_ca_chain()
[DBG ][ESPA]: open_tcp: TCP socket 0 opened: true .
[INFO][TLSW]: Starting TLS handshake with httpbin.org
[DBG ][TLSW]: mbedtls_ssl_setup()
[DBG ][TLSW]: ssl_tls.c:5688: |2| => handshake
[DBG ][TLSW]: ssl_cli.c:4159: |2| client state: 0
[DBG ][TLSW]: ssl_msg.c:2124: |2| => flush output
[DBG ][TLSW]: ssl_msg.c:2136: |2| <= flush output
[DBG ][TLSW]: ssl_cli.c:4159: |2| client state: 1
[DBG ][TLSW]: ssl_cli.c:0872: |2| => write client hello
[DBG ][TLSW]: ssl_msg.c:2560: |2| => write handshake message
[DBG ][TLSW]: ssl_msg.c:2719: |2| => write record
[DBG ][TLSW]: ssl_msg.c:2142: |2| message length: 150, out_left: 150
[DBG ][TLSW]: ssl_msg.c:2148: |2| ssl->f_send() returned 150 (-0xffffff6a)
[DBG ][TLSW]: ssl_msg.c:2176: |2| <= flush output
[DBG ][TLSW]: ssl_msg.c:2890: |2| <= write record
[DBG ][TLSW]: ssl_msg.c:2696: |2| <= write handshake message
[DBG ][TLSW]: ssl_cli.c:1331: |2| <= write client hello
[DBG ][TLSW]: ssl_cli.c:4159: |2| client state: 2
[DBG ][TLSW]: ssl_cli.c:1816: |2| => parse server hello
[DBG ][TLSW]: ssl_msg.c:3922: |2| => read record
[DBG ][TLSW]: ssl_msg.c:1904: |2| => fetch input
[DBG ][TLSW]: ssl_msg.c:2065: |2| in_left: 0, nb_want: 5
[DBG ][TLSW]: ssl_msg.c:2089: |2| in_left: 0, nb_want: 5
[DBG ][TLSW]: ssl_tls.c:5698: |2| <= handshake
[DBG ][TLSW]: ssl_msg.c:2091: |2| ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
[DBG ][TLSW]: ssl_msg.c:2111: |2| <= fetch input
[DBG ][TLSW]: ssl_msg.c:2065: |2| in_left: 5, nb_want: 66
[DBG ][TLSW]: ssl_msg.c:2089: |2| in_left: 5, nb_want: 66
[DBG ][TLSW]: ssl_msg.c:2091: |2| ssl->f_recv(_timeout)() returned 61 (-0xffffffc3)
[DBG ][TLSW]: ssl_msg.c:3996: |2| <= read record
[DBG ][TLSW]: ssl_cli.c:2128: |2| server hello, total extension length: 17
[DBG ][TLSW]: ssl_cli.c:2343: |2| <= parse server hello
[DBG ][TLSW]: ssl_cli.c:4159: |2| client state: 3
[DBG ][TLSW]: ssl_tls.c:2725: |2| => parse certificate
[DBG ][TLSW]: ssl_msg.c:2065: |2| in_left: 5, nb_want: 4839
[DBG ][TLSW]: ssl_msg.c:2089: |2| in_left: 5, nb_want: 4839
[DBG ][TLSW]: ssl_msg.c:2091: |2| ssl->f_recv(_timeout)() returned 2048 (-0xfffff800)
[DBG ][TLSW]: ssl_msg.c:2089: |2| in_left: 2053, nb_want: 4839
[DBG ][TLSW]: ssl_msg.c:2091: |2| ssl->f_recv(_timeout)() returned 2033 (-0xfffff80f)
[DBG ][TLSW]: ssl_msg.c:2089: |2| in_left: 4086, nb_want: 4839
[DBG ][TLSW]: ssl_msg.c:2091: |2| ssl->f_recv(_timeout)() returned 753 (-0xfffffd0f)
What can be the cause of this behavior ? The certificate I set should be correct (got it from my browser), I have no idea what can be the cause.
Any help is very welcome, thanks !
I recall that TLS connection had a minimum RAM requirement, perhaps 128kbytes or something. Check the ram size on your board.
THanks for your reply,
Now that you mention it, I remember reading something about RAM indeed.
I have a custom PCB with a STM32F7 and a ESP-WROOM-02D for wifi, according to espressif documentation it has only 50kB SRAM.
But the program runs on the main STM32F7 which has 512kB SRAM + around 4MB in external SDRAM.
So, I am not sure where does the mbed TLS actually run ? on the ESP or the STM ?
I do not know with what you did it but I tried it with mbed-http and this test code on Nucleo-F429ZI
  • httpbin.org - error
  • https://httpbin.org - get whole page
  • https://httpbin.org/get - get headers and 200 bytes of body
Well, I also was able to send a HTTPS request on a STM32F7-DISCO board connected by ethernet and it worked with no problem.
It only crashes when trying to run the program on custom pcb with STM32F7+ESP8226 via wifi.
After some debugging, I was able to locate the exact place of the crash. It always happens at state 3, when verifying the certificate.
It happens in bignum.c , in the function mbedtls_mpi_grow at this line :
if( ( p = (mbedtls_mpi_uint*)mbedtls_calloc( nblimbs, ciL ) ) == NULL )
So it seems the memory allocation is causing the crash.
However, when inspecting heap size just before this call,
mbed_stats_heap_t heap_stats;
mbed_stats_heap_get(&heap_stats);
printf("Heap size: %lu / %lu bytes\r\n", heap_stats.current_size, heap_stats.reserved_size);
I get : Heap size: 53583 / 500568 bytes, so obviously I have enough memory … so why crash ??
Here is the full callstack just before the crash :
I tried same code, what I mentioned above, with Nucleo-F429ZI and ESP8266-01 and no crash
I was able to solve my problem finally.
I had to increase the main thread stack size (4096 by default) by adding
"rtos.main-thread-stack-size": 8192,
to the target_overrides field of my mbed_app.json file.
It is strange how 4096 is enough to get the TLS socket to work on the DISCO board but not on my PCB.
Anyways, I am happy I was able to solve this problem, thanks @JohnnyK .
Thank you for letting us know the final solution.
Any it is strange because F429ZI has also default size 4096.
Hi there,
I know I’m late on this party and it’s been a long time since this post was published, but is there a chance that you still member the source of this statement regarding there is a minimun RAM requirment for TLSSocket to work?
I’m currently trying t establish a secured TLS connection to a remote host using Nucleo-L432KC platform but to no avail. My test code works great on Nucleo-L476RG platform, which has larger RAM, thus I suspect that L432KC 64KB of RAM is not sufficient .
BR,
Danial
If memory serves, 64K RAM is not enough for TLS. You can add the MBEDTLS_MEMORY_DEBUG macro to mbed_app.json to enable TLS memory debugging. Also check “Using Mbed TLS to communicate securely - Tutorials | Mbed OS 5 Documentation
