I’m trying to make two boards (NUCLEO-F746ZG and NUCLEO-F103RB) to communicate with each other using SPI. However, my slave code does not seem to work on neither of the boards.
In my board master to slave connection as per below
MASTER ( Nulceo F746ZG)
SCK -PE_2
MISO-PE_5
MOSI-PE_6
CS-PE_4
SLAVE( Nulceo F746ZG)
SCK -PE_2
MISO-PE_5
MOSI-PE_6
CS-PE_4
IN Slave Nucleo its Showing Errorbelow
pinmap not found for peripheral
Here i have Attach My Master and Slave Code
This one is Master Code Below
// master Nucleo(F746ZG)
#include"string.h"
Serial pc(USBTX, USBRX); // tx, rx (serial Communication Tera Term)
SPI Master_To_Slave(PE_6,PE_5,PE_2); // mosi, miso, sclk
DigitalOut Slave1_Selection(PE_4); //master NUCLEO-F746ZG slave selection pin
DigitalOut Master_Led(PG_3);
char Send_String[20] = "KALAIVANAN#";
char Received_String[30]="\0";
pc.baud(9600);
int i=0;
int j=0;
int ch;
while (1)
pc.printf("\n Select The case :\n");
pc.scanf("%d",&ch);
switch(ch)
case 1:
pc.printf("nucleo to nucleo SPI Communication\n");
Slave1_Selection = 1; // De_Select the 1st Slave
Master_To_Slave.format(8,3); // Setup: 8bit mode 3
Master_To_Slave.frequency(1000000); // Starting Frequency 1 MHZ
while(Send_String[i] != '\0' ) // Send the String Upto Null
Slave1_Selection = 0; // Select the 1st Slave (Activate)
Received_String[j++] = Master_To_Slave.write(Send_String[i++]); //Data Send to Master and Data Receiver From Master
Master_Led=!Master_Led;//LEd Blinking While Data Transfer
wait_ms(200); // Wait for readability only(Ready to wait for Next Data)
pc.printf("Received String=%s",Received_String);
NVIC_SystemReset();//system reset
break;
paste code here
This one is Slave Code Below
// Slave Nucleo (F746ZG)
#include"string.h"
#include"SPISlave.h"
SPISlave Master_To_Slave(PE_6,PE_5,PE_2,PE_2); //mosi, miso, sclk,SSEL - (Slave Select its activate by master in this pin low mean this Slave Selected )
DigitalOut Slave_Led(PG_3);
char Send_String[25] = "DONE#";
char Received_String[20]="\0";
pc.baud(9600);
Master_To_Slave.frequency(1000000); // Starting Frequency 1MHZ
pc.printf("\n Ready");
int Responce =2024;
int i=0;
int j=0;
Master_To_Slave.reply(++Responce); // SPI with 1st reply
Master_To_Slave.reply(++Responce); // SPI with 2nd reply its just Responces
printf(" \n Replay Last Responce and before while(1)=%d",Responce);
while(1)
if(Master_To_Slave.receive()); // start Reading from Master
Received_String[i++] = Master_To_Slave.read(); // Read Data from master and Stored to Received String
pc.printf("\n Slave1 Received String %s",Received_String); //print the Receiving Char
Slave_Led = !Slave_Led;// LEd Blinking While Data Transfer
Master_To_Slave.reply(Send_String[j++]); //Data Send to Master (Done Message)
pc.printf("\n Sending String %s",Send_String[j++]); //print the sending Char
wait_ms(200);//waiting
wait_ms(10);
NVIC_SystemReset(); //System Reset
