I am trying to build and run some of the Xdot examples from GitHub - MultiTechSystems/dot-examples: Example programs for MultiTech Dot devices demonstrating how to use the Dot devices and the Dot libraries for LoRa communication.
I verified the MBED OS version. I carefully follow the instructions to import the project and add the library. I also updated the MBED OS version carefully to match the version of the library. I get the following link errors if I try to build with stable version of library. I
Error: L6218E: Undefined symbol mts::Text::bin2hexString(std::__2::vector<unsigned char, std::__2::allocator > const&, char const*, bool, bool) (referred from BUILD/XDOT_L151CC/ARMC6/examples/src/dot_util.o).
Error: L6218E: Undefined symbol mDot::setNetworkId(std::__2::vector<unsigned char, std::__2::allocator > const&) (referred from BUILD/XDOT_L151CC/ARMC6/examples/src/dot_util.o).
Error: L6218E: Undefined symbol mDot::setNetworkKey(std::__2::vector<unsigned char, std::__2::allocator > const&) (referred from BUILD/XDOT_L151CC/ARMC6/examples/src/dot_util.o).
Error: L6218E: Undefined symbol mDot::setNetworkName(std::__2::basic_string<char, std::__2::char_traits, std::__2::allocator > const&) (referred from BUILD/XDOT_L151CC/ARMC6/examples/src/dot_util.o).
Error: L6218E: Undefined symbol mDot::setDataSessionKey(std::__2::vector<unsigned char, std::__2::allocator > const&) (referred from BUILD/XDOT_L151CC/ARMC6/examples/src/dot_util.o).
Error: L6218E: Undefined symbol mDot::setNetworkAddress(std::__2::vector<unsigned char, std::__2::allocator > const&) (referred from BUILD/XDOT_L151CC/ARMC6/examples/src/dot_util.o).
Error: L6218E: Undefined symbol mDot::setNetworkPassphrase(std::__2::basic_string<char, std::__2::char_traits, std::__2::allocator > const&) (referred from BUILD/XDOT_L151CC/ARMC6/examples/src/dot_util.o).
Error: L6218E: Undefined symbol mDot::setNetworkSessionKey(std::__2::vector<unsigned char, std::__2::allocator > const&) (referred from BUILD/XDOT_L151CC/ARMC6/examples/src/dot_util.o).
Error: L6218E: Undefined symbol mDot::send(std::__2::vector<unsigned char, std::__2::allocator > const&, bool const&, bool const&) (referred from BUILD/XDOT_L151CC/ARMC6/examples/src/dot_util.o).
Error: L6218E: Undefined symbol std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator >::compare(unsigned int, unsigned int, char const*, unsigned int) const (referred from ./libxdot/libxDot-ARMC6.ar(mDot.o)).
Error: L6218E: Undefined symbol std::__1::__vector_base_common::__throw_length_error() const (referred from ./libxdot/libxDot-ARMC6.ar(mDot.o)).
Error: L6218E: Undefined symbol std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator >::__init(char const*, unsigned int) (referred from ./libxdot/libxDot-ARMC6.ar(mDot.o)).
Error: L6218E: Undefined symbol std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator >::append(char const*, unsigned int) (referred from ./libxdot/libxDot-ARMC6.ar(mDot.o)).
Error: L6218E: Undefined symbol std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator >::assign(char const*) (referred from ./libxdot/libxDot-ARMC6.ar(mDot.o)).
Error: L6218E: Undefined symbol std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator >::basic_string(std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator > const&) (referred from ./libxdot/libxDot-ARMC6.ar(mDot.o)).
Error: L6218E: Undefined symbol std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator >::~basic_string__sub_object() (referred from ./libxdot/libxDot-ARMC6.ar(mDot.o)).
Error: L6218E: Undefined symbol std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator >::operator=(std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator > const&) (referred from ./libxdot/libxDot-ARMC6.ar(mDot.o)).
Error: L6218E: Undefined symbol std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator >::find_first_of(char const*, unsigned int, unsigned int) const (referred from ./libxdot/libxDot-ARMC6.ar(MTSText.o)).
Error: L6218E: Undefined symbol std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator >::find(char, unsigned int) const (referred from ./libxdot/libxDot-ARMC6.ar(MTSText.o)).
Error: L6218E: Undefined symbol std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator >::append(char const*) (referred from ./libxdot/libxDot-ARMC6.ar(MTSText.o)).
Error: L6218E: Undefined symbol std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator >::push_back(char) (referred from ./libxdot/libxDot-ARMC6.ar(MTSText.o)).
Error: L6218E: Undefined symbol std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator >::basic_string(std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator > const&, unsigned int, unsigned int, std::__1::allocator const&) (referred from ./libxdot/libxDot-ARMC6.ar(MTSText.o)).
Finished: 0 information, 1 warning and 22 error messages.
I try with developer version of library and get compiler error. Unable to find “Random_Channel.h” file
Could you please help me in running the Dot examples?
