I’m using MBedOS 5.12
I have a project with two services defined in respective .json files of the form
"name": "MY_SRV",
"type": "APPLICATION-ROT",
"priority": "LOW",
"id": "0x00000180",
"entry_point": "my_task",
"stack_size": "0x2000",
"heap_size": "0x2000",
"services": [
"name": "MY_SERVICE_ID",
"identifier": "0x00000181",
"signal": "GET_STATE",
"non_secure_clients": true,
"minor_version": 1,
"minor_policy": "STRICT"
"extern_sids": [
"MY_EVENT_ID"
"source_files": [
"path/to/my_task.cpp"
I’ve been successfully building for some time. As part of my development, I added a library to a subdirectory of my project. Simply adding a #include sufficed to successfully link in the new library to one of my services. I’m now trying to link it into my other service but I’m getting a link-time error, namely “undefined reference”.
NOTE: I have another library that is being linked into both services without issue so I expected this to also work without issue.
As a check, I found my_task.d and it listed the include files that I would expect to trigger appropriate linking.
Does anyone know what may be causing this to fail to link?
