What happened to the QSPI example for DISCO-L475VG-IOT01A?
https://os.mbed.com/teams/ST/code/DISCO_L475VG_IOT01-QSPI-BSP/
Hi
QSPI example using ST BSP drivers has been removed since QSPI is now directly part of mbed-os
https://os.mbed.com/docs/mbed-os/v5.15/apis/quadspi-qspi.html
@jeromecoutant Thanks for the clarification. As of what version of mbed os is that available? Is there a way to access that old example for older mbed os firmware versions prior to this mbed os change to QSPI?
Thanks!
You should really go to at least mbed-os-5.15 branch…!
ST BSP drivers example source was here:
@jeromecoutant It appears that the QUADSPI driver on mbed is write protected. Is there a way to modify bytes that have been set without erasing the sector or to erase only specific bytes?
