hudakz
(Zoltan Hudak)
May 26, 2020, 11:24am
1
I thought C++ was invented to make programmer’s life easier. However, I have noticed that in the upcoming Mbed OS 6 the Timer’s easy to remember read_ms method is deprecated and we suppose to call a hard to remember:
duration_cast<milliseconds>(elapsed_time()).count()
What is the idea behind such modification to the Timer’s interface? Why isn’t it possible to keep also the human friendly read_ms method name?
hudakz
(Zoltan Hudak)
May 27, 2020, 1:29pm
3
Hello Kentaro,
Thank you for the explanation. I think you are right. That’s most likely why.
Best regards,
Zoltan
star297
(Paul Staron)
June 15, 2020, 12:07pm
4
The example in version 6 Doc’s need to be updated then?
https://os.mbed.com/docs/mbed-os/v6.0/apis/timer.html
timer.read();
timer.read_ms();
timer.read_us();
example:
printf ("Timer time: %d\n", timer.read());
printf ("Timer time: %d\n", timer.read_ms());
printf ("Timer time: %d\n", timer.read_us());
How would I replace these for OS6?
You can do something like this.
Timer t;
t.start();
ThisThread::sleep_for(1s);
t.stop();
auto f = chrono::duration<float>(t.elapsed_time()).count();
auto s = chrono::duration_cast<chrono::seconds>(t.elapsed_time()).count();
auto ms = chrono::duration_cast<chrono::milliseconds>(t.elapsed_time()).count();
auto us = t.elapsed_time().count();
printf ("Timer time: %f s\n", f);
printf ("Timer time: %llu s\n", s);
printf ("Timer time: %llu ms\n", ms);
printf ("Timer time: %llu us\n", us);
// Timer time: 1.002245 s
// Timer time: 1 s
// Timer time: 1002 ms
// Timer time: 1002245 us
star297
(Paul Staron)
June 16, 2020, 10:04am
6
Thank you Kentaro, perfect example!!
hudakz
(Zoltan Hudak)
June 18, 2020, 9:54am
7
To save time, make the source code more readable and avoid frustration with typos, for larger programs one can define macros for example as follows:
#define timer_read_f(x) chrono::duration<float>((x).elapsed_time()).count()
#define timer_read_s(x) chrono::duration_cast<chrono::seconds>((x).elapsed_time()).count();
#define timer_read_ms(x) chrono::duration_cast<chrono::milliseconds>((x).elapsed_time()).count()
#define timer_read_us(x) (x).elapsed_time().count()
Timer t;
t.start();
t.stop();
auto f = timer_read_f(t);
auto s = timer_read_s(t);
auto ms = timer_read_ms(t);
auto us = timer_read_us(t);
star297
(Paul Staron)
June 19, 2020, 7:30am
8
I can understand adding these UNIX standard functions, why not add these defines to the Timer.h file for simplicity for Mbed Rapid Prototyping.
If all you want to do is to print, it makes sense to define timer_read_ms, timer_read_s, etc… But if you compare duration or pass it to a function, maybe you don’t always want to cast it to an integer because doing so breaks type safety.
hudakz
(Zoltan Hudak)
June 21, 2020, 1:26pm
10
I fully agree. In those cases it’s sufficient to call the elapsed_time() method.
JojoS
(Johannes Stratmann)
July 4, 2020, 11:39am
11
there is another good document about the Mbed clocks:
https://github.com/ARMmbed/mbed-os/blob/master/docs/design-documents/platform/clocks/clocks.md
for checking elapsed time, it is not necessary to use a Timer instance. With this snippet from the document it is easy:
//Measuring elapsed time via the RTOS
auto start = Kernel::Clock::now(); // type will be Kernel::Clock::time_point
do_operation();
milliseconds elapsed_time = Kernel::Clock::now() - start;
printf("elapsed time = %d ms\n", int(elapsed_time.count()));
or checking the timepoint:
if (Kernel::Clock::now() - start < 100ms)
return;
chrono is great stuff, but like a landslide in Mbed
There are plenty of interfaces that are still using legacy integers.
hudakz
(Zoltan Hudak)
July 4, 2020, 4:38pm
12
That’s really good to know! Thank you Johannes.
waynek
(Wayne Keenan)
November 27, 2020, 10:36pm
13
This is great, thank you.
It should be the official documentation example, which still uses read() !
