Hi Guys,
I hope I chose the right forum section for my question.
I am trying to record ultrasonic a-mode signals with an Nucleo F446RE board . To do so I am using the Timer2 of the board to create a 1kHz PWM-Signal with a duty-cycle of 1% to drive ultrasonic crystal. This then vibrates and also converts reflected vibrations back into a voltage change. This voltage change is what I also want to measure using the F446RE’s ADC and then transfer it over USB to my laptop.
My question now is can you help me with setting up the ADC-DMA and DMA-USB communications in a way that can handle the fast signal I am dealing with and is able to transfer all data over USB without loosing some in the process?
I am pretty lost at the moment and can’t find a solution so far.
Sincerely Michael
