I am having some really weird problem with mbed + nucleo_f207zg. Can someone offer some pointers?
On a customized PCB built around STM32F207ZGT6, if I leave main stack size as default 8192, then the app works largely fine.
"config": {
"main-stack-size": {
"value": 8192 // changing this line causing trouble
Once I change main stack size to something bigger, such 8196 or 8190, app will crash upon boot.
++ MbedOS Error Info ++
Error Status: 0x80010132 Code: 306 Module: 1
Error Message: Thread: 0x0, Unknown
File: mbed_rtx_handlers.c+115
Error Value: 0x0
Current Thread: <unnamed> Id: 0x0 Entry: 0x8003BCB StackSize: 0x0 StackMem: 0x8005E0D SP: 0x2001FF0C
For more info, visit: https://mbed.com/s/error?error=0x80010132&tgt=NUCLEO_F207ZG
-- MbedOS Error Info --
Changing main stack size to smaller number 4096 doesn’t lead to crash of app.
Information might be relevant:
VCAP_1 and VCAP_2 pins are floating. The board was designed with STM32F303ZE in mind but STM32F207ZG was populated by accident. I feel this might be the main cause. In theory, missing capacitors on those pins will make MCU unstable.
STDIO_UART_TX/RX pins are changed to PB_6 and PB_7, and reused in code.
RawSerial cmdPort(PB_6, PB_7, 115200);
I have done this in previous project and it worked just fine.
I tried Mbed-os-5.14 and 5.15. Both had the same problem though.
When I compile with GCC_ARM V9 I get the following warning, but this warning message doesn’t show up if I compile with GCC_ARM V6. Not sure if this relevant though.
[Warning] rtx_kernel.c@93,3: 'memset' offset [17, 164] from the object at 'osRtxInfo' is out of the bounds of referenced subobject 'kernel' with type 'struct <anonymous>' at offset 8 [-Warray-bounds]
If I wrap the following code into a separate function, then call it instead of inline code, I got weird problems as well.
sendCmdResponse(response, responseLen); /* the commented out lines won't work if wrapped up in a function for (size_t i = 0; i < responseLen; i++) { while (!cmdPort.writeable()) ; cmdPort.putc(response[i]); } */
It is probably safer to just order another batch of PCB but I would like to make sure there is no potential design problems other than VCAP pins.
Thanks.
