I am working on a larger project where I want to disable compiler optimization for proper debugging.
But to trigger my problem this little program is sufficient:
#include “mbed.h”
#define MAXIMUM_BUFFER_SIZE 32
static BufferedSerial SerialPort(USBTX, USBRX);
SerialPort.set_baud(115200);
SerialPort.set_format(8, BufferedSerial::None, 1);
SerialPort.set_blocking(false);
char buf[MAXIMUM_BUFFER_SIZE] = {0};
while (true) {
printf("Before Reading\n");
int num = SerialPort.read(buf, sizeof(buf));
printf("Reading ended, num = %d\n", num);
ThisThread::sleep_for(1s);
(Sorry for the format, for some reason I cannot format it the way I want.)
Using the unmodified debug.json file it works as expected.
But I need to disable compiler optimization so I change “-Og” to “-O0” in the GCC_ARM toolchain of debug.json profile.
When I build and run it like this, I receive this:
When I build and start debugging, the process hangs at ThisThread::sleep_for(1s);
Is there any way to make this work by increasing the stack size or something?
I already looked for this but I only find solutions for deprecated mbed 5 and I use mbed 6.
Thank you for any help!
