Hi there, I can’t reconnect to my Arduino Nano 33 BLE over Bluetooth® LE after the CPU is idle for about 5-10 minutes. The Arduino has a nRF52840 SoC which has support for low power mode. I suspect that Mbed OS enters sleep/deep sleep mode after some time and is unable to walk up from it. To prevent the system from going into sleep I’ve tried calling sleep_manager_lock_deep_sleep as well as implementing a no-op idle hook and calling rtos::Kernel::attach_idle_hook(&idle_hook) before advertising as suggested here but unfortunately the problem persists. Here’s the minimal code (without any error handling) to replicate the issue:
#include "BLE.h"
#include "events/EventQueue.h"
using namespace ble;
using namespace mbed;
static uint8_t advData[31] = {
0x02, 0x01, 0x06, 0x12, 0xFF, 0x4C, 0x00, 0x06,
0x2D, 0x01, 0xFE, 0x6D, 0x74, 0x72, 0xD9, 0xCC,
0x05, 0x00, 0x01, 0x00, 0x01, 0x02, 0x08, 0x08,
0x41, 0x63, 0x6D, 0x65, 0x20, 0x4C, 0x69
static events::EventQueue eq;
void advertise() {
AdvertisingParameters params(
advertising_type_t::CONNECTABLE_UNDIRECTED,
adv_interval_t(millisecond_t(20))
auto &ble = BLE::Instance();
auto &gap = ble.gap();
gap.setAdvertisingParameters(LEGACY_ADVERTISING_HANDLE, params);
gap.setAdvertisingPayload(LEGACY_ADVERTISING_HANDLE, { advData, sizeof(advData) });
gap.startAdvertising(LEGACY_ADVERTISING_HANDLE);
struct EventHandler: public Gap::EventHandler {
void onDisconnectionComplete(const DisconnectionCompleteEvent &event) override {
advertise();
void onInitComplete(BLE::InitializationCompleteCallbackContext *event) {
if (!event->error) {
advertise();
void scheduleEvents(BLE::OnEventsToProcessCallbackContext *event) {
eq.call(&event->ble, &BLE::processEvents);
EventHandler handler;
gap.setEventHandler(&handler);
ble.onEventsToProcess(scheduleEvents);
ble.init(onInitComplete);
eq.dispatch_forever();
I’ve used LightBlue® to connect to the Arduino. If I keep connecting/disconnecting every 2-3 minutes the system doesn’t seem to go into sleep mode. However, if I keep it disconnected for 5-10 minutes it’s no longer discoverable. I’m not sure whether this is a bug or maybe a configuration issue. Any help on how to resolve this, i.e. either prevent sleep or properly wake up on BLE activity, would be appreciated.
