Hi!
Under certain conditions the target C030-R412m does not start anymore. Following an explained routine that describes the problem:
- Power supply (over USB serial connector or through pins) and Battery are both attached.
- Program starts and runs as expected.
- Detach power supply, target runs as expected only with battery.
- After X time, battery is draining and target powers off.
- After some hours, I re-attach the power supply (over USB serial connector or through pins). And here is the problem!
Problem
The target don’t starts and the charger chip never starts to charge the battery. If I attach the power supply through USB with serial data, I don’t get a serial connection. Only the blue led (near serial USB connector if USB power supply used) and the green led near battery charger chip is on. Push reset button does not help and does nothing (no reaction).
To get the target back to work, I need to:
- Remove power supply and battery.
- Re-attach battery and then the power supply.
- Target returns to normal status and all works as expected.
Expected behavior
After re-attaching the power supply, the target should start and the charging chip should start to charge the empty battery.
