looking at this page, it tells you that attach is a function inside callback class.
But when I try to use it, compiler say "no member named attach in 'mbed::callback<void()>'
What is going on or what I do wrong? I use latest mbed.
Thanks in advance.
you did not post the code where you have the issue. Be so kind and share the problematic code.
It is not a big secret.
I need to make SoftSerial working again. There are old definition of attach and fall callbacks that needs to be modified.
I struggle to fix the issues. I don’t think there is any working version out there.
Thanks
BR Mariwan
No I mean, the line of code what give you the error or the line what you want to convert from old system to new one.
Hmm, in case of SoftSerial I remember there were some issue about it. Try to check this topic - SoftSerial problem L432KC - Mbed OS / Hello world! - Arm Mbed OS support forum
Look at this code,
if (RX != NC) {
rx = new InterruptIn(RX);
rx_en = true;
out_valid = false;
rxticker.attach(this, &SoftSerial::rx_handler);
rx->fall(&SoftSerial::rx_gpio_irq_handler); <-- wrong!!
fall defined like that
void fall(Callback<void()> func);
and the error i s
no matching conversion for functional-style cast from 'void' to 'Callback<void ()>'
Maybe the solution is to do like here
rx->fall(std::bind(&SoftSerial::rx_gpio_irq_handler, this));
How I wrote check the topic… Inside is a version of the library with some modifications.
SoftSerial - Not work original Lib on F446RE & L432KC . Change… | Mbed
rx->fall(callback(this, &SoftSerial::rx_gpio_irq_handler));
