Compile a function to a different memory location
Using an stm32f746 disco, I’m trying to get a function to compile to a different memory location using Mbed.
so far, as a test, i have this mbed_app.json…
    "target_overrides": {
            "target.ld_script": "custom_stm32f746.ld"
then this custom_stm32f746.ld…
/* Linker script to configure memory regions. */
MEMORY
FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 1024K
RAM (xrw) : ORIGIN = 0x20000000, LENGTH = 320K
CUSTOM_SECTION (rx) : ORIGIN = 0x080C0000, LENGTH = 128K
/* Define entry point */
ENTRY(Reset_Handler)
/* Section Definitions */
SECTIONS
.text :
*(.text)
*(.text.*)
} > FLASH
.custom_section :
KEEP(*(.custom_section))
} > CUSTOM_SECTION
.data :
*(.data)
} > RAM AT > FLASH
.bss :
*(.bss)
} > RAM
/* Other sections */
View more
and this in my main.c…
__attribute__((section(".custom_section"))) void myFunction(void);
__attribute__((section(".custom_section"), used)) void myFunction() {
        printf("This function is at %0xH\n", (int) myFunction);
but the output is…
This function is at 8000259H
and using the cube programmer the memory at 80c0000 is unchanged
Can you post the .map file? Does it reference myFunction at all?
