- When I flash an ST custom board with an ST-Link programmer/debugger (e.g. cut off a NUCLEO board) using the
copy & pastemethod then it works. - But when I try to program the same custom board using the mbed cli
mbed compile -f ...command then it isn’t flashed (“066F” not found in platform database). This method also fails when I try to program an officially supported mbed board with an ST-Link programmer/debugger which has been cut off the board but then reconnect with wires. - However, when I start to debug the same custom or official mbed board offline by providing the
.elffile then the board is flashed correctly.
