Getting this error when trying to call an assembly file to multiply 2 numbers. I have the file in the directory so I am not sure why it can’t find it.
Hello Chase,
- Do you build with the ARM or GCC_ARM toolchain?
- Which revision of Mbed-OS do you use?
- What is your build tool? Is it the Mbed Studio IDE or the
mbed-cli
(Mbed command line interface)? - Have you tried to use the
.S
extension for the assembly source file name?
