VERY VERY URGENT! KINDLY SOLVE THIS FOR FRDM_KL25Z BOARD. PLEASE WRITE THE CORRECT ANSWER FOR THIS AS IT’S VERY IMPORTANT
Using existing drivers (the drivers are listed below), create a program that flashes the RGBLED in one of two patterns:
- A flashing pattern with a period of 1Hz and an on time of n*10%, where 0<n<10
- A pattern that pulses the LED with a 0.5s on time and a delay of 0.5*n seconds between pulses, where 0<n<10
Note that in both cases, the parameter n can range only from 1 through 9 (inclusive).
A momentary press of the button cycles the parameter n through its range. A longer press (approximately 1.5 s) changes the pattern. Use a single color for the LED.
Use FSM’s for the patterns and to distinguish button presses.
- Red LED driver
redled.c
#include <redled.h>
#include <MKL25Z4.h>
#define RED_LED_LOC 18
void configure_red_led()
SIM->SCGC5 |= SIM_SCGC5_PORTB_MASK;
PORTB->PCR[RED_LED_LOC] =
PORT_PCR_MUX(1) |
PORT_PCR_IRQC(0) |
PORT_PCR_ISF(1);
PTB->PDDR |= (1<<RED_LED_LOC);
void turn_on_red_led()
PTB->PCOR |= (1<<RED_LED_LOC);
void turn_off_red_led()
PTB->PSOR |= (1<<RED_LED_LOC);
void toggle_red_led()
PTB->PTOR |= (1<<RED_LED_LOC);
redled.h
#ifndef REDLED_H
#define REDLED_H
void configure_red_led();
void turn_on_red_led();
void turn_off_red_led();
void toggle_red_led();
#endif
- Switch driver
sw.c
#include <stdbool.h>
#include “sw1.h”
#define SW1_LOCATION 20
void configure_sw1()
SIM->SCGC5 |= SIM_SCGC5_PORTA_MASK;
PORTB->PCR[SW1_LOCATION] =
PORT_PCR_PE(1) |
PORT_PCR_PS(1) |
PORT_PCR_PFE(0) |
PORT_PCR_DSE(0) |
PORT_PCR_SRE(0) |
PORT_PCR_MUX(1) |
PORT_PCR_IRQC(0) |
PORT_PCR_ISF(1);
PTA->PDDR &= ~(1<<SW1_LOCATION);
_Bool sw1_is_pressed()
return !(PTA->PDIR & (1<<SW1_LOCATION));
_Bool sw1_is_not_pressed()
return !sw1_is_pressed();
sw.h
#ifndef SW1_H
#define SW1_H
_Bool sw1_is_pressed();
_Bool sw1_is_not_pressed();
void configure_sw1();
#endif
- Cop driver
cop.c
#include “copwdt.h”
void configure_copwdt()
SIM->COPC= SIM_COPC_COPT(3) |
SIM_COPC_COPCLKS(1) |
SIM_COPC_COPW(0) ;
void feed_the_watchdog()
SIM->SRVCOP = 0x55;
SIM->SRVCOP = 0xAA;
cop.h
#ifndef COPWDT_H
#define COPWDT_H
void configure_copwdt();
void feed_the_watchdog();
#endif
- Systick driver
systick.c
include <systick.h>
static volatile _Bool systick_interrupt_has_occurred=0;
#define SYSTICK_PERIOD (1000)
#define SYSTICK_TOP (SYS_CLOCK / SYSTICK_PERIOD)
void configure_systick()
SysTick->LOAD = SYSTICK_TOP;
SysTick->CTRL = SysTick_CTRL_CLKSOURCE_Msk |
SysTick_CTRL_TICKINT_Msk |
SysTick_CTRL_ENABLE_Msk;
_Bool systick_has_fired()
_Bool retval = systick_interrupt_has_occurred;
return retval;
void SysTick_Handler()
systick_interrupt_has_occurred=1;
systick.h
#ifndef SYSTICK_H
#define SYSTICK_H
#include<stdbool.h>
void configure_systick();
_Bool systick_has_fired();
#endif
