I am Farooq. I am currently working on a project where I have to connect RFID-RC522 to the Nucleo Board F429ZI (Nucleo board has STM 32 microcontroller).
When I compile the code, provided on this link >>RFID-RC522 - voor je boy jens mijn project | Mbed, the Keil studio shows an error as follows:
___________________________________________________________________________________________________________________Build started
Using toolchain ARM_MICRO profile {‘ENV’: {‘ARMLMD_LICENSE_FILE’: ‘8224@10.100.158.60:8224@10.100.125.150’, ‘ARMROOT’: ‘/opt/RVCT_5.03/’, ‘ARMCC41BIN’: ‘/opt/RVCT_5.03/bin’, ‘ARMCC41INC’: ‘/opt/RVCT_5.03/include’, ‘ARMCC41LIB’: ‘/opt/RVCT_5.03/lib’, ‘LANG’: ‘C’}, ‘PATHS’: {‘ARM_PATH’: ‘/opt/RVCT_5.03/’, ‘LIB’: ‘/opt/RVCT_5.03/lib’, ‘CPPLIB’: ‘/opt/RVCT_5.03/lib/cpplib’, ‘INC’: ‘/opt/RVCT_5.03/include’, ‘BIN’: ‘/opt/RVCT_5.03/bin’}, ‘common’: [‘-c’, ‘–gnu’, ‘-O3’, ‘-Otime’, ‘–split_sections’, ‘–apcs=interwork’, ‘-D__MICROLIB’, ‘–library_type=microlib’], ‘cxx’: [‘–cpp’, ‘–no_rtti’], ‘COMPILE_C_AS_CPP’: False, ‘PATCHED_LIBRARY’: False}
scan /tmp/chroots/ch-44cd7dbf-742c-4a19-803e-f3fd326b4cac/src
scan /tmp/chroots/ch-44cd7dbf-742c-4a19-803e-f3fd326b4cac/extras/mbed
Configuration error: ‘static_memory_defines’ is not defined.
Fatal error: C3903U: Argument ‘Cortex-M4.fp.sp’ not permitted for option ‘cpu’.
compile MFRC522.cpp
Internal error.
Build failed
Build failed
Kindly guide where should I made adjustments to the code in order for it to work or if there is a place where I can find out the code for my project to make the RC522 work with the Nucleo Board F429ZI.
I hope that clarifies my query! Feel free to ask for any further clarification. I will be more than happy to assist you in this regard!
Best regards,
Farooq
