Hi Im trying to run the MBED client example as a test and although i have got through the build process and have the bin file. When I try to copy it in to the boards flash drive i get an error saying there isnt enough memory? The bin is 254kb
Can you please be more specific about what yotta target you used (run yt target in the directory to find out) and which example repository you used (please provide a link to it)?
the target is the K64f
the board fails to accept transfer of the file due to the size. seems odd considering that the example if for this board.
Try updating the firmware to the latest version. Instructions can be found here : FRDM-K64F | Mbed
