I believe the join sequence will be broken and the end-device will never join if it receives a data message when expecting a join accept message.
An end-device will transmit a join request on a given channel and then open a receive window expecting to receive nothing or a join accept. It is possible that another end-device could transmit on the same channel in which case the first end-device will receive a data uplink message. It is also possible that a gateway transmits a downlink intended for another end-device.
I believe this could be a real problem in a highly congested LoRaWAN installation.
If the transceiver fails to receive anything during an RX window LoRaWANStack::rx_timeout_interrupt_handler will get called and rx_timeout_interrupt_handler will continue the join sequence.
If the transceiver receives something in the RX window LoRaWANStack::rx_interrupt_handler will be called. rx_interrupt_handler calls LoRaWANStack::process_reception calls LoRaMac::on_radio_rx_done and they get in a mess if mac_hdr.bits.mtype != FRAME_TYPE_JOIN_ACCEPT.
Interestingly LoRaMac::on_radio_rx_done contains this code:
default:
// This can happen e.g. if we happen to receive uplink of another device
// during the receive window. Block RX2 window since it can overlap with
// QOS TX and cause a mess.
tr_debug("RX unexpected mtype %u", mac_hdr.bits.mtype);
if (get_current_slot() == RX_SLOT_WIN_1) {
_lora_time.stop(_params.timers.rx_window2_timer);
_mcps_indication.status = LORAMAC_EVENT_INFO_STATUS_ADDRESS_FAIL;
_mcps_indication.pending = false;
break;
but I don’t think this helps during the join sequence. This code was added by this PR LoRaWAN: Terminate RX when receiving uplink messages #11241.
I’ve come up with a suggested fix but clearly it is very difficult to reason about and test:
diff --git a/features/lorawan/LoRaWANStack.cpp b/features/lorawan/LoRaWANStack.cpp
index 79f899ef2a..a4a9833305 100644
--- a/features/lorawan/LoRaWANStack.cpp
+++ b/features/lorawan/LoRaWANStack.cpp
@@ -715,6 +715,10 @@ void LoRaWANStack::process_reception(const uint8_t *const payload, uint16_t size
if (!_loramac.nwk_joined()) {
+ _device_current_state = DEVICE_STATE_AWAITING_JOIN_ACCEPT;
+ if (_loramac.get_current_slot() != RX_SLOT_WIN_1) {
+ state_controller(DEVICE_STATE_JOINING);
_ready_for_rx = true;
return;
Any thoughts greatly appreciated.
Matt
