LWIP_TCPIP_THREAD - stack size limit reached?
I am assuming that this is the thread that is reaching a limit of 1200 when printing thread stack statistics. It is an OS thread, as I do not have any of my own with that size stack limit. After a couple of web server requests, it reports that the MaxStack is equal to the Stack size. Is this normal.
Tried changing the definition in mbed_config.h - but it had no effect - ? may have to recompile whole OS to change it.
Thanks
the mbed_config.h file has very important note at the beginning
// Automatically generated configuration file.
// DO NOT EDIT, content will be overwritten.
For changing stack size and many more gonfiguration you need create/edit mbed_app.json file. For more information and better understanding look to - The configuration system - Program setup | Mbed OS 6 Documentation
The default value of parameter tcpip-thread-stacksize is in the mbed_lib.json here.
The override of that parameter via mbed_app.json file might look like this
    "target_overrides": {
        "lvip.tcpip-thread-stacksize": 2000
Thanks - I am using an Arduino Portenta H7 as my device. I tried adding the mbed_app.json with the following contents in my project root directory (where the arduino code resides). My main thread stack never exceeds 3k - as it does nothing after the initializations, except sleep forever - so I modified that as well.
            "target.lse_available": "1",
			"lwip.tcpip-thread-stacksize": 4096,
			"rtos.main-thread-stack-size": 8192
However, when running the program, there is no difference in the Max Stack sizes reported.
      Thread: 0x2400ee1c, Stack size: 32768, Max stack: 2824
      Thread: 0x2400f728, Stack size: 1200, Max stack: 168
Should I be adding the mbed_app.json file somewhere else? There is very little support on this subject in the Portenta forums.
Thanks again.
How I remember Arduino does not use Mbed OS 1:1 , it is wrapped in some patches.
So you need to research Arduino sources. Good start seems to be here - ArduinoCore-mbed - Customizing Mbed OS build without modifying the code
Thanks, I had seen that before, and I had tried in a number of locations before to no avail.
It is now OS 3.2, and I have tried modifying the standard mbed_app.json in
C:\Users\RS\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\3.2.0\variants\PORTENTA_H7_M7\libs
as well as adding it to a number of other directories under variants, but it is never accessed (as per properties), and does not change the stack sizes as per the entries.
I closed and reopened the IDE, to force a clean compile as well.
The complete mbed_app,json file - including the preexisting mods is
      "target.printf_lib": "std",
      "platform.stdio-buffered-serial": false,
      "platform.default-serial-baud-rate": 115200,
      "platform.callback-nontrivial": true,
      "platform.all-stats-enabled": true,
      "platform.memory-tracing-enabled": true,
			"rtos.main-thread-stack-size": 8192,
      "cordio.max-connections": 5,
      "cellular.debug-at": true,
      "cellular.offload-dns-queries": true,
      "cellular.at-handler-buffer-size": 512,
      "mbed-trace.enable": true,
      "target.mbed_app_start": "0x8040000",
      "target.macros_add": [
        "BT_UART_NO_3M_SUPPORT",
        "USB_DYNAMIC_CONFIGURATION",
        "METAL_INTERNAL",
        "VIRTIO_MASTER_ONLY",
        "NO_ATOMIC_64_SUPPORT",
        "METAL_MAX_DEVICE_REGIONS=2",
        "RPMSG_BUFFER_SIZE=2048"
According to
the path should be PORTENTA_H7_M7\conf and not PORTENTA_H7_M7\libs
Sorry, that was a cut and paste issue.
I tried it in the \conf directory,
I also tried it in the base directory (above conf), my sketch project root directory, i created a conf directory in my project, and added it there as well.
None of them seem to have mace a difference,
Unless the contents of tbe mbed_app.json file is issue (i have no other way to test that).
Ok, I am out of ideas, last tip. Are you sure you have selected the PORTENTA_H7_M7 and not the PORTENTA_H7_M4?
afaik, the Arduino-Mbed core is using a precompiled archive for the core, so the mbed-app.json cannot have an effect on the mbed core settings. I guess you need to compile a new core archive.
Unfortunately, I had Pretty frustrating.
Recompiling the mbed core is not a very windows friendly procedure.
I tried
and the boards do not appear in the IDE, also, I do not think the ./mbed-os-to-arduino runs under windows.
I have access to a raspberry pi, should I try it under that, create a new libmbed.a file and try moving iot to the directory below?
I am working in Windows, not Linux
I downloaded Cygwin
I also downloaded and installed mingw64 – and verified I can compile a .cpp programs with g++
I then downloaded the repositiory
Made the changes in the conf/mbed_app.json file
I then go to the root of the repository, and execute
./mbed-os-to-arduino -r ./variants/PORTENTA_H7_M7/libs PORTENTA_H7_M7:PORTENTA_H7_M7
And, I get the following error message
$ ./mbed-os-to-arduino -r ./variants/PORTENTA_H7_M7/libs PORTENTA_H7_M7:PORTENTA_H7_M7
./mbed-os-to-arduino: line 2: $‘\r’: command not found
: invalid optionuino: line 3: set: -
set: usage: set [-abefhkmnptuvxBCHP] [-o option-name] [–] [arg …]
./mbed-os-to-arduino: line 4: $‘\r’: command not found
./mbed-os-to-arduino: line 5: syntax error near unexpected token `$‘{\r’’
'/mbed-os-to-arduino: line 5: `check_tools () {
Any ideas?
I tried running it is a Raspberry Pi 4 that I have
I downloaded and extracted the repository in a directory.
I cd to that directory
I run
$ ./mbed-os-to-arduino -r ./variants/PORTNETA_H7_M7/libs PORTENTA_H7_M7:PORTENTAA_H7_M7
I then get this error
MBED_CLEAN=0
MBED_UPDATE=0
APPLY_PATCHES=0
RESTORE_GDB_INFO=0
LOCAL_REPO=./variants/PORTENTA_H7_M7/libs
REMOTE_BRANCH=
MBED_CORE_LOCATION=/home/rsalasidis/GithubRep/ArduinoCore-mbed-master
VARIANT=PORTENTA_H7_M7 BOARD=PORTENTA_H7_M7
Checking for prerequisites… done.
Creating MbedOS Application…/mbed-os-to-arduino: line 25: mbed: command not found
I tried to run the above line in the mbed_cli (that I installed as well), and I get
‘mbed-os-to-arduino’ is not recognized as an internal or external command,
operable program or batch file.
Any idea the easiest way to do this.
Via the mbed_studio in windows probably be the easiest for me if possible
Thanks
