Hi team,
For programming my mBED LPC1768 board I have connected it to my PC and entered into Keil studio cloud. But in the device manger my device is not showing. Kindly help me in this regard.
1.) check the USB port connected or not?
2.) change usb to B type cable.
3.) login your keil id
4.) select active project and build target
this issue is usually happen because of old DAP’s firmware which not support WEB USB
New beta firmware for LPC1768 - Keil Studio - Arm Mbed OS support forum
Can I program mBED LPC1768 in an offline PC? I have installed Keil u Vision 5. What are the additional packages to be installed, kindly help me.
Is there any way to program mBED LPC1768 in offline mode. I came to know its possible through keil software. If so, which version is required and supporting package. Kindly help me. I am new to micro controller programming.
You can do it with MbedCE, but if you want work with Keil uVision then you probably need to visit their websides and look for something around DAP-link maybe - UVISION DEBUGGER: uVision does not Detect Mbed DAPLink (arm.com)
Is it like CLI? How to install it?
I do not understand what should be a CLI from your point of view but MbedCE is fork of ARM Mbed repo in hands of community as compensation of retired Mbed - Important update on Mbed - End of Life - Mbed OS - Arm Mbed OS support forum
