I’m having problems getting the mbed OS example client to resolve my local Leshan test server through the border router.
I think this due to the device not being able to find the server via the local-link layer and I was hoping for some pointers on how to track down the fault.
For a bit of background I’ve implemented a low level interface to the WIZnet 6100 chip and I can confirm through looking at the data getting sent via Wireshark and debugging output for both the client and router (all listed below) that ethernet messages are getting sent and received but it’s still failing to connect.
Any help would be appreciated.
Chris
-------Mbed OS Example ---------
Starting mbed Client example
[EasyConnect] IPv6 mode
[EasyConnect] Using Mesh (EFR32)
[EasyConnect] Connecting to Mesh…
[INFO][TjoA]: Generating Random MAC
[INFO][TjoA]: Generating Random ML-EID
[INFO][addr]: Address added to IF 1:
[INFO][m6Thread]: Start Thread bootstrap (Router mode)
[INFO][TjoA]: From NVM 0
[INFO][TjoA]: mac-counter 0
[INFO][TjoA]: mle-counter 0
[INFO][TjoA]: seq-counter 0
[INFO][tnvm]: link info not cached
[INFO][TjoA]: thread_joiner_application_configuration_nvm_save
[INFO][thbs]: thread network attach start
[INFO][addr]: Address added to IF 1: fe80::96:969f:64e6:81f2
[INFO][addr]: Address added to IF 1: fd00:db8::f2f4:da66:f672:333c
[INFO][tnvm]: thread_nvm_store_link_info_get addr zeros
[WARN][thbs]: thread_nvm_store_link_info_get returned -1
[INFO][tebs]: Parent Response
[INFO][tebs]: Recv Child ID Response
[INFO][thbs]: Network data updated
[INFO][thrd]: New prefix added
[INFO][thrd]: New server entry made
[INFO][TMFs]: Joiner router Disable joining
[INFO][thbs]: Set forwarding: ip=1, multicast=0
[INFO][m6Thread]: Thread bootstrap ready
[EasyConnect] Connected to Network successfully
[EasyConnect] MAC address 02:96:96:9f:64:e6:81:f2
[EasyConnect] IP address fdaa:bbcc:ddee:0:96:969f:64e6:81f2
[INFO][mClt]: connection_event_handler: default type: 0
SOCKET_MODE : UDP
Connecting to coap://fdaa:bbcc:ddee:0:f0d2:6ee2:7cf9:792:5683
handle_timer_tick, device not registered
[WARN][ip6r]: LL addr of not found
[ERR ][mClt]: M2MNsdlInterface::received_from_server_callback - registration error 2
[ERROR:] M2MInterface::NetworkError
[WARN][sck ]: sendto:No interface
[WARN][sck ]: fail: socket_buffer_sendmsg
[ERR ][nsif]: socket_sendmsg: error=-4
[INFO][addr]: Address added to IF 1: fdaa:bbcc:ddee:0:96:969f:64e6:81f2
[ERR ][coap]: sn_coap_builder_options_build - options not used!
[WARN][ip6r]: LL addr of fdaa:bbcc:ddee:0:f0d2:6ee2:7cf9:792 not found
----------- Border router ---------------------
[DBG ][core]: Allocate Root Tasklet
[DBG ][6lo]: P.Init
[DBG ][swm]: Set MAC mode to IEEE 802.15.4-2011, MTU size: 127
[DBG ][core]: NS Root task Init
[DBG ][sck]: Socket Tasklet Generated
[INFO][app]: Starting NanoStack Border Router…
[INFO][app]: Build date: Sep 8 2020 12:34:33
[INFO][app]: Mbed OS: 60201
[INFO][brro]: NET_IPV6_BOOTSTRAP_STATIC
[INFO][brro]: backhaul_prefix: fdaa:bbcc:ddee::
[INFO][brro]: next hop: ::
[INFO][brro]: backhaul route prefix: ::
[DBG ][WIZnet]: MAC addr: 2:0:0:0:0:1
[INFO][app]: Using WIZnet backhaul driver…
[INFO][WIZnet]: SPEED: 100MB, DUPLEX: FULL SPEED, MODE: AUTO
[INFO][WIZnet]: LINK: UP, CABLE: ATTACHED
[DBG ][WIZnet]: Device interrupt enabled and set
[DBG ][WIZnet]: Setup basic IP and MAC address
[DBG ][WIZnet]: Finished connecting device
[DBG ][WIZnet]: Setting up driver id: 1
[DBG ][WIZnet]: WIZnet opening MACRAW socket
[DBG ][WIZnet]: WIZnet setting up interrupt mask
[DBG ][WIZnet]: Finished setting up the device
[DBG ][brro]: Create Mesh Interface
[INFO][brro]: thread_if_id: 1
[DBG ][mPKe]: Set new Key main Class
[DBG ][thbs]: Allocate Thread Tasklet
[DBG ][mMIB]: Set key 3
[DBG ][thrm]: Register Discovery device descriptor
[INFO][brro]: thread_interface_up
[INFO][brro]: PAN ID abcd
[INFO][brro]: RF channel 11
[DBG ][tBRa]: thread_border_router_init if=1
[DBG ][ThSA]: service init interface 1, port 61631, options 0
[DBG ][ThSA]: service tasklet init
[DBG ][sck]: Socket id 0 allocated
[DBG ][ThSA]: Service 1, Uri registration uri: a/nd
[DBG ][tBBR]: thread_border_router_init if=1
[DBG ][ThSA]: service init interface 1, port 49191, options 130
[DBG ][sck]: Socket id 1 allocated
[DBG ][ThSA]: Service 3, Uri registration uri: c/mg
[DBG ][ThSA]: Service 3, Uri registration uri: c/ag
[DBG ][ThSA]: Service 3, Uri registration uri: c/pg
[DBG ][ThSA]: Service 3, Uri registration uri: c/tx
[DBG ][ThSA]: Service 3, Uri registration uri: c/cp
[DBG ][ThSA]: Service 3, Uri registration uri: c/ca
[DBG ][ThSA]: Service 3, Uri registration uri: c/cs
[DBG ][ThSA]: Service 3, Uri registration uri: c/cg
[DBG ][ThSA]: Service 4, Uri registration uri: c/rt
[DBG ][ThSA]: Service 4, Uri registration uri: c/re
[DBG ][ThSA]: Service 4, Uri registration uri: c/mg
[DBG ][ThSA]: Service 4, Uri registration uri: c/ag
[DBG ][ThSA]: Service 4, Uri registration uri: c/pg
[DBG ][ThSA]: Service 4, Uri registration uri: c/cg
[DBG ][ThSA]: Service 4, Uri registration uri: c/pq
[DBG ][ThSA]: Service 4, Uri registration uri: c/es
[DBG ][ThSA]: Service 4, Uri registration uri: c/ab
[DBG ][ThSA]: Service 4, Uri registration uri: d/dg
[DBG ][ThSA]: Service 4, Uri registration uri: d/dr
[DBG ][ThSA]: Service 4, Uri registration uri: d/dq
[DBG ][TjoA]: Mesh local eid: 0:
[DBG ][TjoA]: extended random: 0:
[DBG ][TjoA]: uri: (none)
[DBG ][TjoA]: name: ARM ltd
[DBG ][TjoA]: mode: MbedOS
[DBG ][TjoA]: version: 1.1
[DBG ][TjoA]: vendor data:
[DBG ][TjoA]: NwkName: 54:68:72:65:61:64:20:4e:65:74:77:6f:72:6b:0:
[DBG ][TjoA]: Mesh ula: fd:0:
[DBG ][TjoA]: Extendend PanId: f1:b5:a1:b2:c4:d5:a1:bd
[DBG ][TjoA]: panid: 43981, Channel:11, keyRot:3600, keySeq:0
[INFO][thrm]: set new link timeout 100 , old value 240
[INFO][addr]: Address added to IF 1: fe80::fd6f:d00:85cc:20fe
[DBG ][addr]: LL64 Register OK!
[DBG ][sck]: Socket id 2 allocated
[DBG ][thbs]: Set ASPIRING Router Mode
[DBG ][rout]: Added route:
[DBG ][rout]: fe80::/64 if:1 src:‘Static’ id:0 lifetime:infinite
[DBG ][rout]: On-link (met 128)
[DBG ][rout]: ff00::/8 if:1 src:‘Static’ id:0 lifetime:infinite
[DBG ][rout]: On-link (met 192)
[INFO][brro]: mesh0 bootstrap ongoing…
[DBG ][brro]: Backhaul driver ID: 1
[DBG ][brro]: backhaul_interface_up: 1
[DBG ][brro]: Backhaul interface ID: 2
[INFO][tBBR]: Thread BBR start if:1, bb_if:2
[DBG ][sck]: Socket id 3 allocated
[WARN][sck]: No address
[WARN][sck]: fail: socket_buffer_sendmsg
[DBG ][rout]: fdaa:bbcc:ddee::/64 if:2 src:‘Static’ id:0 lifetime:infinite
[DBG ][rout]: On-link (met 64)
[DBG ][pIP6]: IPV6 interface Base Ready
[DBG ][rout]: fe80::/64 if:2 src:‘Static’ id:0 lifetime:infinite
[DBG ][rout]: ff00::/8 if:2 src:‘Static’ id:0 lifetime:infinite
[DBG ][brro]: Backhaul bootstrap started
[INFO][addr]: Tentative Address added to IF 2: fe80::ff:fe00:1
[DBG ][thbs]: Thread task Init
[DBG ][ThSA]: service tasklet initialised
[DBG ][WIZnet]: Sending data via data-link layer
[DBG ][WIZnet]: Rx data-link layer reading data
[DBG ][WIZnet]: Rx data-link received: -3020
[DBG ][WIZnet]: Rx data-link clearing interrupts
[DBG ][WIZnet]: Rx data-link received: 62
[DBG ][WIZnet]: Rx MAC. PTR: 0x20001552, LENGTH: 60
[DBG ][WIZnet]: Rx data-link processed: 62 / 62
[DBG ][WIZnet]: Rx data-link received: 124
[DBG ][WIZnet]: Rx MAC. PTR: 0x20001590, LENGTH: 60
[DBG ][WIZnet]: Rx data-link processed: 124 / 124
[DBG ][WIZnet]: Rx data-link received: 557
[DBG ][WIZnet]: Rx MAC. PTR: 0x200015ce, LENGTH: 369
[DBG ][WIZnet]: Rx MAC. PTR: 0x20001741, LENGTH: 60
[DBG ][WIZnet]: Rx data-link processed: 557 / 557
[DBG ][WIZnet]: Rx data-link received: 1308
[DBG ][WIZnet]: Rx MAC. PTR: 0x2000177f, LENGTH: 369
[DBG ][WIZnet]: Rx MAC. PTR: 0x200018f2, LENGTH: 378
[DBG ][WIZnet]: Rx data-link processed: 1308 / 1308
[DBG ][WIZnet]: Rx data-link received: 1750
[DBG ][WIZnet]: Rx MAC. PTR: 0x20001a6e, LENGTH: 378
[DBG ][WIZnet]: Rx MAC. PTR: 0x20001bea, LENGTH: 60
[DBG ][WIZnet]: Rx data-link processed: 1750 / 1750
[DBG ][WIZnet]: Rx data-link received: 1874
[DBG ][WIZnet]: Rx MAC. PTR: 0x20001c28, LENGTH: 60
[DBG ][WIZnet]: Rx MAC. PTR: 0x20001c66, LENGTH: 60
[DBG ][WIZnet]: Rx data-link processed: 1874 / 1874
[DBG ][WIZnet]: Rx data-link received: 1936
[DBG ][WIZnet]: Rx MAC. PTR: 0x20001ca4, LENGTH: 60
[DBG ][WIZnet]: Rx data-link processed: 1936 / 1936
[DBG ][WIZnet]: Rx data-link received: 1998
[DBG ][WIZnet]: Rx MAC. PTR: 0x20001ce2, LENGTH: 60
[DBG ][WIZnet]: Rx data-link processed: 1998 / 1998
