I’m trying to migrate our K64F based code to a similar board, but which leverages the Micro KSZ8794 rather than the standard KSZ8081. Additionally, we have moved over to using the SPI interface of the KSZ8794 rather than the MIIM interface to allow better management of the switch chip. The phy seems to come up properly and get a good link and complete auto-negotiation, but the LWIP stack fails to complete DHCP, I suspect due to an issue with sending or receiving data over the RMII interface. (The RMII pins are still the same as on the standard FRDM K64F interface, except the MIIM pins are disconnected.
Is there anything special that needs to be done to port the Phy and Emac drivers in MBED for the K64F?
I’ve included the code for the ports below:
SwitchPhy.cpp
Copyright (c) 2015, Freescale Semiconductor, Inc.
Copyright 2016-2017 NXP
Redistribution and use in source and binary forms, with or without modification,
are permitted provided that the following conditions are met:
o Redistributions of source code must retain the above copyright notice, this list
of conditions and the following disclaimer.
o Redistributions in binary form must reproduce the above copyright notice, this
list of conditions and the following disclaimer in the documentation and/or
other materials provided with the distribution.
o Neither the name of the copyright holder nor the names of its
contributors may be used to endorse or promote products derived from this
software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS “AS IS” AND
ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include “SwitchPhy.h”
#include “PinNames.h”
#include “mbed.h”
- Definitions
/*! @brief Defines the timeout macro. */
#define PHY_TIMEOUT_COUNT 0xFFFFFU
#define REG_PORT_1_STATUS_3 0x1F
#define PORT_PHY_SOFT_RESET (1 << 4)
#define REG_PORT_1_CTRL_10 0x1D
#define PORT_AUTO_NEG_RESTART (1 << 5)
#define KS_PORT_NUM 4
- Variables
SPI spi(PTB22, PTB23, PTB21, PTB20);
extern uint32_t ENET_GetInstance(ENET_Type *base);
#if !(defined(FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL) && FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL)
/*! @brief Pointers to enet clocks for each instance. */
extern clock_ip_name_t s_enetClock[FSL_FEATURE_SOC_ENET_COUNT];
#endif /* FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL */
- Code
status_t Ksz8794_Init(ENET_Type *base, uint32_t phyAddr, uint32_t srcClock_Hz)
uint32_t counter = PHY_TIMEOUT_COUNT;
uint32_t idReg = 0;
status_t result = kStatus_Success;
spi.format(8, 0);
spi.frequency(1000000);
uint32_t addr = 0x01;
uint32_t resp;
Ksz8794_Read(base, phyAddr, addr, &resp);
for(int i = 0; i < KS_PORT_NUM - 1; i++)
Ksz8794_Write(base, phyAddr, REG_PORT_1_STATUS_3 + i*0x10, PORT_PHY_SOFT_RESET );
printf("2\n");
ThisThread::sleep_for(10);
printf("3\n");
//fnet_fec_mii_write(ethif, FNET_FEC_MII_REG_CR, FNET_FEC_MII_REG_CR_ANE|FNET_FEC_MII_REG_CR_ANE_RESTART);
Ksz8794_Write(base, phyAddr, REG_PORT_1_CTRL_10 + i*0x10, PORT_AUTO_NEG_RESTART);
printf("Switch Initialized\n");
return result;
status_t Ksz8794_AutoNegotiation(ENET_Type *base, uint32_t phyAddr)
uint32_t bssReg;
/* Set the negotiation. */
result = Ksz8794_Write(base, phyAddr, 0x1D, 0x20);
if (result == kStatus_Success)
/* Check auto negotiation complete. */
while (counter --)
result = Ksz8794_Read(base, phyAddr, 0x1E, &bssReg);
if ( result == kStatus_Success)
if ((bssReg & 0x40) != 0)
break;
if (!counter)
printf("Negotiation Failed");
return kStatus_PHY_AutoNegotiateFail;
return result;
status_t Ksz8794_Write(ENET_Type *base, uint32_t phyAddr, uint32_t phyReg, uint32_t data)
char input_buf[3];
char output_buf[3];
input_buf[0] = 0x40 | (((phyReg & 0x80) == 0x80) ? 1 : 0); /* Write command | A7 */
input_buf[1] = (phyReg&0x7F) << 1;
input_buf[2] = data;
spi.select();
spi.write(input_buf, 3, output_buf, 3);
spi.deselect();
return kStatus_Success;
status_t Ksz8794_Read(ENET_Type *base, uint32_t phyAddr, uint32_t phyReg, uint32_t *dataPtr)
assert(dataPtr);
char input_buf[3];
char output_buf[3];
input_buf[0] = 0x60 | (((phyReg & 0x80) == 0x80) ? 1 : 0); /* Read command | A7 */
input_buf[2] = 0xFF;
spi.select();
spi.deselect();
*dataPtr = output_buf[2];
status_t Ksz8794_EnableLoopback(ENET_Type *base, uint32_t phyAddr, phy_loop_t mode, bool enable)
status_t result;
uint32_t data = 0;
/* Set the loop mode. */
if (enable)
if (mode == kPHY_LocalLoop)
/* First read the current status in control register. */
result = Ksz8794_Read(base, phyAddr, PHY_BASICCONTROL_REG, &data);
return Ksz8794_Write(base, phyAddr, PHY_BASICCONTROL_REG, (data | PHY_BCTL_LOOP_MASK));
else
result = Ksz8794_Read(base, phyAddr, PHY_CONTROL2_REG, &data);
return Ksz8794_Write(base, phyAddr, PHY_CONTROL2_REG, (data | PHY_CTL2_REMOTELOOP_MASK));
else
/* Disable the loop mode. */
/* First read the current status in the basic control register. */
return Ksz8794_Write(base, phyAddr, PHY_BASICCONTROL_REG, (data & ~PHY_BCTL_LOOP_MASK));
else
/* First read the current status in control one register. */
return Ksz8794_Write(base, phyAddr, PHY_CONTROL2_REG, (data & ~PHY_CTL2_REMOTELOOP_MASK));
return result;
status_t Ksz8794_GetLinkStatus(ENET_Type *base, uint32_t phyAddr, bool *status)
//printf("Get Status\n");
assert(status);
uint32_t resp;
Ksz8794_Read(base, phyAddr, 0x1E, &resp);
printf("Status register = 0x%X\n", resp);
uint32_t data;
/* Read the basic status register. */
result = Ksz8794_Read(base, phyAddr, 0x1E, &data);
// printf("Status register = 0x%X\n", (data));
// printf("value check = %s\n", ((1 << 5) & data)? "Good":"Bad");
if (!((1 << 5) & data))
/* link down. */
*status = false;
//printf("Status Good");
else
/* link up. */
*status = true;
return result;
status_t Ksz8794_GetLinkSpeedDuplex(ENET_Type *base, uint32_t phyAddr, phy_speed_t *speed, phy_duplex_t *duplex)
assert(duplex);
uint32_t data, ctlReg;
/* Read the control two register. */
result = Ksz8794_Read(base, phyAddr, 0x1F, &ctlReg);
data = ctlReg & PHY_CTL1_SPEEDUPLX_MASK;
if ((PHY_CTL1_10FULLDUPLEX_MASK == data) || (PHY_CTL1_100FULLDUPLEX_MASK == data))
/* Full duplex. */
*duplex = kPHY_FullDuplex;
else
/* Half duplex. */
*duplex = kPHY_HalfDuplex;
if ((PHY_CTL1_100HALFDUPLEX_MASK == data) || (PHY_CTL1_100FULLDUPLEX_MASK == data))
/* 100M speed. */
*speed = kPHY_Speed100M;
else
/* 10M speed. */
*speed = kPHY_Speed10M;
return result;
SwitchEMAC.cpp
Copyright (c) 2013 - 2014, Freescale Semiconductor, Inc.
Copyright (c) 2017 ARM Limited
All rights reserved.
o Neither the name of Freescale Semiconductor, Inc. nor the names of its
#include <ctype.h>
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include “cmsis_os.h”
#include “mbed_interface.h”
#include “mbed_assert.h”
#include “netsocket/nsapi_types.h”
#include “mbed_shared_queues.h”
#include “SwitchEMAC.h”
#include “EmacConfig.h”
#include “mbed_power_mgmt.h”
using namespace std::chrono;
enet_handle_t switch_g_handle;
// TX Buffer descriptors
uint8_t *switch_tx_desc_start_addr;
// RX Buffer descriptors
uint8_t *switch_rx_desc_start_addr;
// RX packet buffer pointers
emac_mem_buf_t *switch_rx_buff[ENET_RX_RING_LEN];
// TX packet buffer pointers
emac_mem_buf_t *switch_tx_buff[ENET_TX_RING_LEN];
// RX packet payload pointers
uint32_t *switch_rx_ptr[ENET_RX_RING_LEN];
- Internal data
#define ENET_BuffSizeAlign(n) ENET_ALIGN(n, ENET_BUFF_ALIGNMENT)
#define ENET_ALIGN(x,align) ((unsigned int)((x) + ((align)-1)) & (unsigned int)(~(unsigned int)((align)- 1)))
extern “C” void kinetis_init_eth_hardware(void);
/* \brief Flags for worker thread */
#define FLAG_TX 1
#define FLAG_RX 2
/** \brief Driver thread priority */
#define THREAD_PRIORITY (osPriorityNormal)
#define PHY_TASK_PERIOD 200ms
SwitchEMAC::SwitchEMAC() : xTXDCountSem(ENET_TX_RING_LEN, ENET_TX_RING_LEN), hwaddr()
static osThreadId_t create_new_thread(const char *threadName, void (*thread)(void *arg), void *arg, int stacksize, osPriority_t priority, mbed_rtos_storage_thread_t *thread_cb)
osThreadAttr_t attr = {0};
attr.name = threadName;
attr.stack_mem = malloc(stacksize);
attr.cb_mem = thread_cb;
attr.stack_size = stacksize;
attr.cb_size = sizeof(mbed_rtos_storage_thread_t);
attr.priority = priority;
return osThreadNew(thread, arg, &attr);
- Buffer management
- This function will queue a new receive buffer
static void update_read_buffer(uint8_t *buf)
if (buf != NULL) {
switch_g_handle.rxBdCurrent->buffer = buf;
/* Clears status. */
switch_g_handle.rxBdCurrent->control &= ENET_BUFFDESCRIPTOR_RX_WRAP_MASK;
/* Sets the receive buffer descriptor with the empty flag. */
switch_g_handle.rxBdCurrent->control |= ENET_BUFFDESCRIPTOR_RX_EMPTY_MASK;
/* Increases the buffer descriptor to the next one. */
if (switch_g_handle.rxBdCurrent->control & ENET_BUFFDESCRIPTOR_RX_WRAP_MASK) {
switch_g_handle.rxBdCurrent = switch_g_handle.rxBdBase;
} else {
switch_g_handle.rxBdCurrent++;
/* Actives the receive buffer descriptor. */
ENET->RDAR = ENET_RDAR_RDAR_MASK;
/** \brief Free TX buffers that are complete
void SwitchEMAC::tx_reclaim()
/* Get exclusive access */
TXLockMutex.lock();
// Traverse all descriptors, looking for the ones modified by the uDMA
while ((tx_consume_index != tx_produce_index) &&
(!(switch_g_handle.txBdDirty->control & ENET_BUFFDESCRIPTOR_TX_READY_MASK))) {
memory_manager->free(switch_tx_buff[tx_consume_index % ENET_TX_RING_LEN]);
if (switch_g_handle.txBdDirty->control & ENET_BUFFDESCRIPTOR_TX_WRAP_MASK) {
switch_g_handle.txBdDirty = switch_g_handle.txBdBase;
} else {
switch_g_handle.txBdDirty++;
tx_consume_index += 1;
xTXDCountSem.release();
/* Restore access */
TXLockMutex.unlock();
/** \brief Ethernet receive interrupt handler
This function handles the receive interrupt.
void SwitchEMAC::rx_isr()
if (thread) {
osThreadFlagsSet(thread, FLAG_RX);
void SwitchEMAC::tx_isr()
osThreadFlagsSet(thread, FLAG_TX);
void SwitchEMAC::ethernet_callback(ENET_Type *base, enet_handle_t *handle, enet_event_t event, void *param)
SwitchEMAC *enet = static_cast<SwitchEMAC *>(param);
switch (event) {
case kENET_RxEvent:
enet->rx_isr();
break;
case kENET_TxEvent:
enet->tx_isr();
break;
default:
break;
/** \brief Low level init of the MAC and PHY.
bool SwitchEMAC::low_level_init_successful()
uint8_t i;
uint32_t sysClock;
phy_speed_t phy_speed;
phy_duplex_t phy_duplex;
uint32_t phyAddr = 0;
enet_config_t config;
// Allocate RX descriptors
switch_rx_desc_start_addr = (uint8_t *)calloc(1, sizeof(enet_rx_bd_struct_t) * ENET_RX_RING_LEN + ENET_BUFF_ALIGNMENT);
if (!switch_rx_desc_start_addr) {
return false;
// Allocate TX descriptors
switch_tx_desc_start_addr = (uint8_t *)calloc(1, sizeof(enet_tx_bd_struct_t) * ENET_TX_RING_LEN + ENET_BUFF_ALIGNMENT);
if (!switch_tx_desc_start_addr) {
return false;
switch_rx_desc_start_addr = (uint8_t *)ENET_ALIGN(switch_rx_desc_start_addr, ENET_BUFF_ALIGNMENT);
switch_tx_desc_start_addr = (uint8_t *)ENET_ALIGN(switch_tx_desc_start_addr, ENET_BUFF_ALIGNMENT);
/* Create buffers for each receive BD */
for (i = 0; i < ENET_RX_RING_LEN; i++) {
switch_rx_buff[i] = memory_manager->alloc_heap(ENET_ETH_MAX_FLEN, ENET_BUFF_ALIGNMENT);
if (NULL == switch_rx_buff[i]) {
return false;
switch_rx_ptr[i] = (uint32_t *)memory_manager->get_ptr(switch_rx_buff[i]);
//printf("3\n");
tx_consume_index = tx_produce_index = 0;
/* prepare the buffer configuration. */
enet_buffer_config_t buffCfg = {
ENET_RX_RING_LEN,
ENET_TX_RING_LEN,
ENET_ALIGN(ENET_ETH_MAX_FLEN, ENET_BUFF_ALIGNMENT),
0,
(volatile enet_rx_bd_struct_t *)switch_rx_desc_start_addr,
(volatile enet_tx_bd_struct_t *)switch_tx_desc_start_addr,
(uint8_t *) &switch_rx_ptr,
NULL,
kinetis_init_eth_hardware();
sysClock = CLOCK_GetFreq(kCLOCK_CoreSysClk);
ENET_GetDefaultConfig(&config);
if (Ksz8794_Init(ENET, phyAddr, sysClock) != kStatus_Success) {
return false;
/* Get link information from PHY */
Ksz8794_GetLinkSpeedDuplex(ENET, phyAddr, &phy_speed, &phy_duplex);
/* Change the MII speed and duplex for actual link status. */
config.miiMode = kENET_RmiiMode;
config.miiSpeed = (enet_mii_speed_t)phy_speed;
config.miiDuplex = (enet_mii_duplex_t)phy_duplex;
config.interrupt = kENET_RxFrameInterrupt | kENET_TxFrameInterrupt;
config.rxMaxFrameLen = ENET_ETH_MAX_FLEN;
config.macSpecialConfig = kENET_ControlFlowControlEnable;
config.txAccelerConfig = 0;
config.rxAccelerConfig = kENET_RxAccelMacCheckEnabled;
ENET_Init(ENET, &switch_g_handle, &config, &buffCfg, hwaddr, sysClock);
ENET_SetCallback(&switch_g_handle, &SwitchEMAC::ethernet_callback, this);
ENET_ActiveRead(ENET);
printf("EMAC 3\n");
return true;
/** \brief Allocates a emac_mem_buf_t and returns the data from the incoming packet.
\param[in] idx index of packet to be read
\return a emac_mem_buf_t filled with the received packet (including MAC header)
emac_mem_buf_t *SwitchEMAC::low_level_input(int idx)
volatile enet_rx_bd_struct_t *bdPtr = switch_g_handle.rxBdCurrent;
emac_mem_buf_t *p = NULL;
emac_mem_buf_t *temp_rxbuf = NULL;
uint32_t length = 0;
const uint16_t err_mask = ENET_BUFFDESCRIPTOR_RX_TRUNC_MASK | ENET_BUFFDESCRIPTOR_RX_CRC_MASK |
ENET_BUFFDESCRIPTOR_RX_NOOCTET_MASK | ENET_BUFFDESCRIPTOR_RX_LENVLIOLATE_MASK;
#ifdef LOCK_RX_THREAD
TXLockMutex.lock();
#endif
/* Determine if a frame has been received */
if ((bdPtr->control & err_mask) != 0) {
/* Re-use the same buffer in case of error */
update_read_buffer(NULL);
} else {
/* A packet is waiting, get length */
length = bdPtr->length;
/* Zero-copy */
p = switch_rx_buff[idx];
memory_manager->set_len(p, length);
/* Attempt to queue new buffer */
temp_rxbuf = memory_manager->alloc_heap(ENET_ETH_MAX_FLEN, ENET_BUFF_ALIGNMENT);
if (NULL == temp_rxbuf) {
/* Re-queue the same buffer */
#endif
return NULL;
switch_rx_buff[idx] = temp_rxbuf;
switch_rx_ptr[idx] = (uint32_t *)memory_manager->get_ptr(switch_rx_buff[idx]);
update_read_buffer((uint8_t *)switch_rx_ptr[idx]);
osMutexRelease(TXLockMutex);
#endif
return p;
/** \brief Attempt to read a packet from the EMAC interface.
void SwitchEMAC::input(int idx)
emac_mem_buf_t *p;
/* move received packet into a new buf */
p = low_level_input(idx);
if (p == NULL) {
return;
emac_link_input_cb(p);
/** \brief Worker thread.
Woken by thread flags to receive packets or clean up transmit
\param[in] pvParameters pointer to the interface data
void SwitchEMAC::thread_function(void *pvParameters)
struct SwitchEMAC *kinetis_enet = static_cast<SwitchEMAC *>(pvParameters);
for (;;) {
uint32_t flags = osThreadFlagsWait(FLAG_RX | FLAG_TX, osFlagsWaitAny, osWaitForever);
MBED_ASSERT(!(flags & osFlagsError));
if (flags & FLAG_RX) {
kinetis_enet->packet_rx();
if (flags & FLAG_TX) {
kinetis_enet->packet_tx();
/** \brief Packet reception task
This task is called when a packet is received. It will
pass the packet to the LWIP core.
void SwitchEMAC::packet_rx()
static int idx = 0;
while ((switch_g_handle.rxBdCurrent->control & ENET_BUFFDESCRIPTOR_RX_EMPTY_MASK) == 0) {
input(idx);
idx = (idx + 1) % ENET_RX_RING_LEN;
/** \brief Transmit cleanup task
This task is called when a transmit interrupt occurs and
reclaims the buffer and descriptor used for the packet once
the packet has been transferred.
void SwitchEMAC::packet_tx()
tx_reclaim();
/** \brief Low level output of a packet. Never call this from an
interrupt context, as it may block until TX descriptors -
become available. -
\param[in] buf the MAC packet to send (e.g. IP packet including MAC addresses and type)
\return ERR_OK if the packet could be sent or an err_t value if the packet couldn’t be sent
bool SwitchEMAC::link_out(emac_mem_buf_t *buf)
// If buffer is chained or not aligned then make a contiguous aligned copy of it
if (memory_manager->get_next(buf) ||
reinterpret_cast<uint32_t>(memory_manager->get_ptr(buf)) % ENET_BUFF_ALIGNMENT) {
emac_mem_buf_t *copy_buf;
copy_buf = memory_manager->alloc_heap(memory_manager->get_total_len(buf), ENET_BUFF_ALIGNMENT);
if (NULL == copy_buf) {
memory_manager->free(buf);
return false;
// Copy to new buffer and free original
memory_manager->copy(copy_buf, buf);
buf = copy_buf;
/* Check if a descriptor is available for the transfer (wait 10ms before dropping the buffer) */
if (!xTXDCountSem.try_acquire_for(10)) {
return false;
TXLockMutex.lock();
/* Save the buffer so that it can be freed when transmit is done */
switch_tx_buff[tx_produce_index % ENET_TX_RING_LEN] = buf;
tx_produce_index += 1;
/* Setup transfers */
switch_g_handle.txBdCurrent->buffer = static_cast<uint8_t *>(memory_manager->get_ptr(buf));
switch_g_handle.txBdCurrent->length = memory_manager->get_len(buf);
switch_g_handle.txBdCurrent->control |= (ENET_BUFFDESCRIPTOR_TX_READY_MASK | ENET_BUFFDESCRIPTOR_TX_LAST_MASK);
/* Increase the buffer descriptor address. */
if (switch_g_handle.txBdCurrent->control & ENET_BUFFDESCRIPTOR_TX_WRAP_MASK) {
switch_g_handle.txBdCurrent = switch_g_handle.txBdBase;
} else {
switch_g_handle.txBdCurrent++;
/* Active the transmit buffer descriptor. */
ENET->TDAR = ENET_TDAR_TDAR_MASK;
return true;
- PHY task: monitor link
#define STATE_UNKNOWN (-1)
#define STATE_LINK_DOWN (0)
#define STATE_LINK_UP (1)
void SwitchEMAC::phy_task()
// Get current status
PHY_STATE crt_state;
bool connection_status;
Ksz8794_GetLinkStatus(ENET, phyAddr, &connection_status);
if (connection_status) {
crt_state.connected = STATE_LINK_UP;
} else {
crt_state.connected = STATE_LINK_DOWN;
if (crt_state.connected == STATE_LINK_UP) {
//printf("Phy Negotiation\n");
if (prev_state.connected != STATE_LINK_UP) {
Ksz8794_AutoNegotiation(ENET, phyAddr);
Ksz8794_GetLinkSpeedDuplex(ENET, phyAddr, &crt_state.speed, &crt_state.duplex);
// if (prev_state.connected != STATE_LINK_UP || crt_state.speed != prev_state.speed) {
// /* Poke the registers*/
// ENET_SetMII(ENET, (enet_mii_speed_t)crt_state.speed, (enet_mii_duplex_t)crt_state.duplex);
// Compare with previous state
if (crt_state.connected != prev_state.connected && emac_link_state_cb) {
emac_link_state_cb(crt_state.connected);
prev_state = crt_state;
bool SwitchEMAC::power_up()
/* Initialize the hardware */
if (!low_level_init_successful()) {
return false;
// Can't enter deep sleep as long as Ethernet is active
sleep_manager_lock_deep_sleep();
/* Worker thread */
thread = create_new_thread("SwitchEMAC_thread", &SwitchEMAC::thread_function, this, THREAD_STACKSIZE, THREAD_PRIORITY, &thread_cb);
/* Trigger thread to deal with any RX packets that arrived before thread was started */
rx_isr();
/* PHY monitoring task */
prev_state.connected = STATE_LINK_DOWN;
prev_state.speed = (phy_speed_t)STATE_UNKNOWN;
prev_state.duplex = (phy_duplex_t)STATE_UNKNOWN;
mbed::mbed_event_queue()->call(mbed::callback(this, &SwitchEMAC::phy_task));
/* Allow the PHY task to detect the initial link state and set up the proper flags */
osDelay(10);
phy_task_handle = mbed::mbed_event_queue()->call_every(PHY_TASK_PERIOD, mbed::callback(this, &SwitchEMAC::phy_task));
return true;
uint32_t SwitchEMAC::get_mtu_size() const
return KINETIS_ETH_MTU_SIZE;
uint32_t SwitchEMAC::get_align_preference() const
return ENET_BUFF_ALIGNMENT;
void SwitchEMAC::get_ifname(char *name, uint8_t size) const
memcpy(name, KINETIS_ETH_IF_NAME, (size < sizeof(KINETIS_ETH_IF_NAME)) ? size : sizeof(KINETIS_ETH_IF_NAME));
uint8_t SwitchEMAC::get_hwaddr_size() const
return KINETIS_HWADDR_SIZE;
bool SwitchEMAC::get_hwaddr(uint8_t *addr) const
return false;
void SwitchEMAC::set_hwaddr(const uint8_t *addr)
memcpy(hwaddr, addr, sizeof hwaddr);
ENET_SetMacAddr(ENET, const_cast<uint8_t *>(addr));
void SwitchEMAC::set_link_input_cb(emac_link_input_cb_t input_cb)
emac_link_input_cb = input_cb;
void SwitchEMAC::set_link_state_cb(emac_link_state_change_cb_t state_cb)
emac_link_state_cb = state_cb;
void SwitchEMAC::add_multicast_group(const uint8_t *addr)
ENET_AddMulticastGroup(ENET, const_cast<uint8_t *>(addr));
void SwitchEMAC::remove_multicast_group(const uint8_t *addr)
// ENET HAL doesn't reference count - ENET_LeaveMulticastGroup just maps
// address to filter bit, and clears that bit, even if shared by other
// addresses. So don't attempt anything for now.
void SwitchEMAC::set_all_multicast(bool all)
if (all) {
ENET->GAUR = 0xFFFFFFFFu;
ENET->GALR = 0xFFFFFFFFu;
void SwitchEMAC::power_down()
// Ethernet went down, can enter deep sleep
sleep_manager_unlock_deep_sleep();
void SwitchEMAC::set_memory_manager(EMACMemoryManager &mem_mngr)
memory_manager = &mem_mngr;
SwitchEMAC &SwitchEMAC::get_instance()
static SwitchEMAC emac;
return emac;
// Weak so a module can override
MBED_WEAK EMAC &EMAC::get_default_instance()
return SwitchEMAC::get_instance();
/* --------------------------------- End Of File ------------------------------ */
