Hi, I’m using mbed OS for my master thesis project. Things are going great, however I need to use MQTT for letting my ST-Nucleo board communicate with my server. Is there any MQTT client compatible with mbed OS?
There is yotta - build better software which is based off the MQTT module on mbed Classic, but I haven’t tried it.
@janjongboom Thank you very much, I’ll give it a try.
I had to modify it in order to make it compatible with mbed OS async Sockets and minar, I used the Async MQTT client and now it seems to work (at least with QOS 0). Thank you again @janjongboom ![]()
2017 Update: Here is an MQTT library for mbed OS 5 based on Paho MQTT.
Hello Carmelo Migliore
Can you please share the modified version of the program, that you have worked on, to get the MQTT Client program compatible with mBedOS?
Or
Can you please share the program link directly on prasanna.am@gmail.com
