I am trying to run nanostack-border-router with k66f + spirit1.
After the build, the flash was smooth, but there is no console output on the serial monitor.
What modifications are needed to solve this?
nanostack-border-router import master branch mbed-os-6.8.0
The mbed_app.json settings are as follows:
"config": {
"radio-type":{
"help": "options are ATMEL, MCR20, SPIRIT1",
"value": "SPIRIT1"
"backhaul-driver": {
"help": "options are ETH, SLIP, EMAC",
"value": "EMAC"
"mesh-mode": {
"help": "Mesh networking mode. Options are LOWPAN_ND and THREAD",
"value": "LOWPAN_ND"
"backhaul-mac-src": {
"help": "Where to get EUI48 address. Options are BOARD, CONFIG",
"value": "BOARD"
"nanostack_extended_heap": {
"help": "Add additional memory region to nanostack heap. Valid only for selected platforms. Region size may vary depending of the toolchain.",
"value": false
"backhaul-mac": "{0x02, 0x00, 0x00, 0x00, 0x00, 0x01}",
"slip_hw_flow_control": "false",
"slip_serial_baud_rate": "921600",
"debug-trace": "false",
"defined-BR-config": "true",
"security-mode": "NONE",
"psk-key-id": 1,
"psk-key": "{0xa0, 0xa1, 0xa2, 0xa3, 0xa4, 0xa5, 0xa6, 0xa7, 0xa8, 0xa9, 0xaa, 0xab, 0xac, 0xad, 0xae, 0xaf}",
"pana-mode": "",
"tls-psk-key": "{0xcf, 0xce, 0xcd, 0xcc, 0xcb, 0xca, 0xc9, 0xc8, 0xc7, 0xc6, 0xc5, 0xc4, 0xc3, 0xc2, 0xc1, 0xc0}",
"tls-psk-key-id": 1,
"pan-id": "0x0691",
"network-id": "network000000000",
"beacon-protocol-id": 4,
"prefix": "fd00:db8::",
"prefix-from-backhaul": true,
"rf-channel": 12,
"rf-channel-page": 0,
"rf-channel-mask": "0x07fff800",
"short-mac-address": "0xface",
"backhaul-dynamic-bootstrap": true,
"backhaul-prefix": "fd00:db8:ff1::",
"backhaul-default-route": "::/0",
"backhaul-next-hop": "fe80::1",
"ra-router-lifetime": 1024,
"rpl-instance-id": 1,
"rpl-idoublings": 9,
"rpl-imin": 12,
"rpl-k": 10,
"rpl-max-rank-inc": 2048,
"rpl-min-hop-rank-inc": 128,
"rpl-default-lifetime": 64,
"rpl-lifetime-unit": 60,
"rpl-pcs": 1,
"rpl-ocp": 1,
"multicast-addr": "ff05::7",
"LED": "NC",
"SERIAL_TX": "NC",
"SERIAL_RX": "NC",
"SERIAL_CTS": "NC",
"SERIAL_RTS": "NC"
"target_overrides": {
"target.network-default-interface-type": "ETHERNET",
"nsapi.default-stack": "NANOSTACK",
"mbed-trace.enable": 1,
"nanostack.configuration": "lowpan_border_router",
"mbed-mesh-api.heap-size": 40000,
"mbed-mesh-api.heap-stat-info": "&memory_heap_stat",
"mbed-mesh-api.heap-stat-info-definition": "mem_stat_t memory_heap_stat;"
"K64F": {
"LED": "LED_GREEN",
"SERIAL_TX": "PTE0",
"SERIAL_RX": "PTE1",
"SERIAL_CTS": "PTE2",
"SERIAL_RTS": "PTE3",
"kinetis-emac.tx-ring-len":4,
"kinetis-emac.rx-ring-len":4
"K66F": {
"LED": "LED_GREEN",
