Hi all,
I’m trying run nanostack-border-router with X-NUCLEO-S2868A1 (S2LP) with minimal configuration changes. But still getting
[ERR ][s2lp]: Failed to change state from 0 to: 30
[ERR ][s2lp]: Failed to change state from 0 to: 5c
Antenna is original from x-nucleo. Any hits how to debug what’s going on?
Config is:
“config”: {
“radio-type”:{
“help”: “options are ATMEL, MCR20”,
“value”: “S2LP”
“backhaul-driver”: {
“help”: “options are ETH, SLIP, EMAC, CELL”,
“value”: “EMAC”
“mesh-mode”: {
“help”: “Mesh networking mode. Options are LOWPAN_ND and THREAD”,
“value”: “THREAD”
“backhaul-mac-src”: {
“help”: “Where to get EUI48 address. Options are BOARD, CONFIG”,
“value”: “BOARD”
“backhaul-mld”: {
“help”: “Enable proxying Multicast Listener Discovery messages to backhaul network”,
“value”: “false”
“nanostack_extended_heap”: {
“help”: “Add additional memory region to nanostack heap. Valid only for selected platforms. Region size may vary depending of the toolchain.”,
“value”: false
“backhaul-mac”: “{0x02, 0x00, 0x00, 0x00, 0x00, 0x01}”,
“rf-channel”: 22,
“rf-channel-page”: 0,
“rf-channel-mask”: “0x07fff800”,
“debug-trace”: 1,
“backhaul-dynamic-bootstrap”: true,
“backhaul-prefix”: ““fd00:300::””,
“backhaul-next-hop”: ““fe80::1"”,
“backhaul-default-route”: “”::/0"”,
“commissioning-dataset-timestamp”: “0x00010000”,
“pan-id”: “0x0700”,
“extended-pan-id”: “{0xf1, 0xb5, 0xa1, 0xb2,0xc4, 0xd5, 0xa1, 0xbd }”,
“mesh-local-prefix”: “{0xfd, 0x0, 0x0d, 0xb8, 0x0,0x0, 0x0, 0x0}”,
“network-name”: ““Thread Network””,
“pskd”: ““ABCDEFGH””,
“pskc”: “{0xc8, 0xa6, 0x2e, 0xae, 0xf3, 0x68, 0xf3, 0x46, 0xa9, 0x9e, 0x57, 0x85, 0x98, 0x9d, 0x1c, 0xd0}”,
“thread-master-key”: “{0x10, 0x11, 0x22, 0x33, 0x44, 0x55, 0x66, 0x77, 0x88, 0x99, 0xaa, 0xbb, 0xcc, 0xdd, 0xee, 0xff}”,
“thread-use-static-link-config”: false,
“thread-security-policy”: 255,
“LED”: “NC”,
“SERIAL_TX”: “NC”,
“SERIAL_RX”: “NC”,
“SERIAL_CTS”: “NC”,
“SERIAL_RTS”: “NC”
“macros”: [“MBEDTLS_USER_CONFIG_FILE=“source/mbedtls_thread_config.h””],
“target_overrides”: {
“target.network-default-interface-type”: “ETHERNET”,
“nsapi.default-stack”: “NANOSTACK”,
“mbed-trace.enable”: 1,
“nanostack.configuration”: “thread_border_router”,
“platform.stdio-convert-newlines”: true,
“platform.stdio-baud-rate”: 115200,
“mbed-mesh-api.heap-size”: 65535,
“mbed-mesh-api.heap-stat-info”: “&memory_heap_stat”,
“mbed-mesh-api.heap-stat-info-definition”: “mem_stat_t memory_heap_stat;”
Thank you
Stepan
