Hello everyone, I am writing this post to ask for help regarding a strange issue with printf.
I’m using mbedos 6.8 and mbed studio 1.3.1.
The board that I use is no longer supported by mebedos 6.x (while it was supported in mbed os 5).
https://github.com/makerdiary/nrf52840-mdk
However the board uses the well-known mcu nrf52840.
So I have edited some json file:
custom_targets.json
"NRF52840_MDK": {
"inherits": ["MCU_NRF52840"],
"components_remove": ["QSPIF"],
"overrides": {
"lf_clock_src": "NRF_LF_SRC_SYNTH"
"device_name": "nRF52840_xxAA",
"detect_code": ["0230"]
targets.json
I have added :
“NRF52840_MDK”: {
“inherits”: [
“MCU_NRF52840”
“macros_add”: [
“CONFIG_GPIO_AS_PINRESET”
“config”: {
“enable-objects-extensions”: {
“help”: “Enable inclusion of objects_extensions.h”,
“value”: false
“supported_application_profiles”: [
“full”, “bare-metal”
mbed_lib.json
I have added the lines:
“NRF52840_MDK”:{
“platform.stdio-baud-rate”: 9600,
“platform.stdio-convert-newlines”: true
and finally accordinng to board pinout I have created a folder (copied from nrf52840_dk) : mbedos\targets\TARGET_NORDIC\TARGET_NRF5x\TARGET_NRF52\TARGET_MCU_NRF52840\TARGET_NRF52840_MDK
and i have modify the lines:
**LED1 = p23,**
** LED2 = p22,**
** LED3 = p24,**
** BUTTON1 = p32,**
** //BUTTON2 = p12,**
** //BUTTON3 = p24,**
** //BUTTON4 = p25,**
**RX_PIN_NUMBER = p19,**
** TX_PIN_NUMBER = p20,**
CTS_PIN_NUMBER = p7,
RTS_PIN_NUMBER = p5,
// mBed interface Pins
**USBTX = TX_PIN_NUMBER,**
** USBRX = RX_PIN_NUMBER,**
** STDIO_UART_TX = TX_PIN_NUMBER,**
** STDIO_UART_RX = RX_PIN_NUMBER,**
STDIO_UART_CTS = CTS_PIN_NUMBER,
STDIO_UART_RTS = RTS_PIN_NUMBER,
at this point I write my first blinking program and it work! well fine. now i try to use the serial with the printf/scanf so I write a very simple code as:
#include “mbed.h”
DigitalOut led_red(LED1);
#define BLINKING_RATE 500
{while (true) { wait_us(BLINKING_RATE*1000); led_red=!led_red; printf("Hello world!\n"); }}
and I use putty or mbed serial monitor (9600,8,1) but the result is similar some time all work fine but often a couple of lines are written correctly and then everything stops like:
Hello world!
Hello world!
Hello world!
He
some time if I open putty i view daplink:overflow
Based on your experience what can I do? Is correct how I defined the pinnames? Any setting in the json files? The daplink to update? What am I doing wrong?
thank you
Marco
