I’m using the mbed-http library to make a HTTP POST request with TLS. But when I compile the program (using the online compiler) and run it on L-Tek FF-LPC546XX, nothing happens at all. There’s nothing to see in the serial monitor. If I comment out all the code that is related to the http request (from “printf(”\n----- HTTPS POST request -----\n"" and downwards) the program runs perfectly and connects to the wifi-network.
I’m able to make a http post request (without TLS), with no problems.
I’m using a ESP8266 connected to the board.
Could you help me out? Thanks.
#include "https_request.h"
#include "TLSSocket.h"
//SSL Certificate
const char SSL_CA_PEM[] = "-----BEGIN CERTIFICATE-----\n"
"MIIEdTCCA12gAwIBAgIJAKcOSkw0grd/MA0GCSqGSIb3DQEBCwUAMGgxCzAJBgNV\n"
"BAYTAlVTMSUwIwYDVQQKExxTdGFyZmllbGQgVGVjaG5vbG9naWVzLCBJbmMuMTIw\n"
"MAYDVQQLEylTdGFyZmllbGQgQ2xhc3MgMiBDZXJ0aWZpY2F0aW9uIEF1dGhvcml0\n"
"eTAeFw0wOTA5MDIwMDAwMDBaFw0zNDA2MjgxNzM5MTZaMIGYMQswCQYDVQQGEwJV\n"
"UzEQMA4GA1UECBMHQXJpem9uYTETMBEGA1UEBxMKU2NvdHRzZGFsZTElMCMGA1UE\n"
"ChMcU3RhcmZpZWxkIFRlY2hub2xvZ2llcywgSW5jLjE7MDkGA1UEAxMyU3RhcmZp\n"
"ZWxkIFNlcnZpY2VzIFJvb3QgQ2VydGlmaWNhdGUgQXV0aG9yaXR5IC0gRzIwggEi\n"
"MA0GCSqGSIb3DQEBAQUAA4IBDwAwggEKAoIBAQDVDDrEKvlO4vW+GZdfjohTsR8/\n"
"y8+fIBNtKTrID30892t2OGPZNmCom15cAICyL1l/9of5JUOG52kbUpqQ4XHj2C0N\n"
"Tm/2yEnZtvMaVq4rtnQU68/7JuMauh2WLmo7WJSJR1b/JaCTcFOD2oR0FMNnngRo\n"
"Ot+OQFodSk7PQ5E751bWAHDLUu57fa4657wx+UX2wmDPE1kCK4DMNEffud6QZW0C\n"
"zyyRpqbn3oUYSXxmTqM6bam17jQuug0DuDPfR+uxa40l2ZvOgdFFRjKWcIfeAg5J\n"
"Q4W2bHO7ZOphQazJ1FTfhy/HIrImzJ9ZVGif/L4qL8RVHHVAYBeFAlU5i38FAgMB\n"
"AAGjgfAwge0wDwYDVR0TAQH/BAUwAwEB/zAOBgNVHQ8BAf8EBAMCAYYwHQYDVR0O\n"
"BBYEFJxfAN+qAdcwKziIorhtSpzyEZGDMB8GA1UdIwQYMBaAFL9ft9HO3R+G9FtV\n"
"rNzXEMIOqYjnME8GCCsGAQUFBwEBBEMwQTAcBggrBgEFBQcwAYYQaHR0cDovL28u\n"
"c3MyLnVzLzAhBggrBgEFBQcwAoYVaHR0cDovL3guc3MyLnVzL3guY2VyMCYGA1Ud\n"
"HwQfMB0wG6AZoBeGFWh0dHA6Ly9zLnNzMi51cy9yLmNybDARBgNVHSAECjAIMAYG\n"
"BFUdIAAwDQYJKoZIhvcNAQELBQADggEBACMd44pXyn3pF3lM8R5V/cxTbj5HD9/G\n"
"VfKyBDbtgB9TxF00KGu+x1X8Z+rLP3+QsjPNG1gQggL4+C/1E2DUBc7xgQjB3ad1\n"
"l08YuW3e95ORCLp+QCztweq7dp4zBncdDQh/U90bZKuCJ/Fp1U1ervShw3WnWEQt\n"
"8jxwmKy6abaVd38PMV4s/KCHOkdp8Hlf9BRUpJVeEXgSYCfOn8J3/yNTd126/+pZ\n"
"59vPr5KW7ySaNRB6nJHGDn2Z9j8Z3/VyVOEVqQdZe4O/Ui5GjLIAZHYcSNPYeehu\n"
"VsyuLAOQ1xk4meTKCRlb/weWsKh/NEnfVqn3sF/tM+2MR7cwA130A4w=\n"
"-----END CERTIFICATE-----\n";
WiFiInterface *wifi;
const char* ssid = "KammeratBladfjeder"; //SSID for ESP8266
const char* pwd = "XXXXXXXXXX"; //Password for ESP8266
printf("Start\n");
wifi = WiFiInterface::get_default_instance();
if (!wifi) {
printf("ERROR: No WiFiInterface found.\n");
printf("\nConnecting to %s...\n", ssid);
int ret = wifi->connect(ssid, pwd, NSAPI_SECURITY_WPA2);
if (ret != 0) {
printf("\nConnection error: %d\n", ret);
printf("Success\n\n");
printf("MAC: %s\n", wifi->get_mac_address());
printf("IP: %s\n", wifi->get_ip_address());
printf("Netmask: %s\n", wifi->get_netmask());
printf("Gateway: %s\n", wifi->get_gateway());
printf("RSSI: %d\n\n", wifi->get_rssi());
printf("\n----- HTTPS POST request -----\n");
const char body[] = "{\"hello\":\"world\"}";
HttpsRequest* request = new HttpsRequest(wifi, SSL_CA_PEM, HTTP_POST, "https://httpbin.org/post");
request->set_header("Content-Type", "application/json");
HttpResponse* response = request->send(body, strlen(body));
// if response is NULL, check response->get_error()
printf("status is %d - %s\n", response->get_status_code(), response->get_status_message());
printf("body is:\n%s\n", response->get_body_as_string().c_str());
delete request;
