Hello everyone,
I’m working on a project using Lorawan in which I need to send 7 bytes over Lora. I’m using the LoraAPI example and I only can send data byte to byte. Therefore I modified the code by using the send function 7 times to send my data to the gateway. By the way, I’m using TTN console to see the data I sent. It seems to send properly (I’m looking at the serial transmission if the board sends the send confirmation message. And I check with LEDs too.
Here is my code (sorry it’s not very clean)
- Copyright (c) 2017, Arm Limited and affiliates.
- SPDX-License-Identifier: Apache-2.0
- Licensed under the Apache License, Version 2.0 (the “License”);
- you may not use this file except in compliance with the License.
- You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0 - Unless required by applicable law or agreed to in writing, software
- distributed under the License is distributed on an “AS IS” BASIS,
- WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- See the License for the specific language governing permissions and
- limitations under the License.
#include <stdio.h>
#include “mbed.h”
#include “lorawan/LoRaWANInterface.h”
#include “lorawan/system/lorawan_data_structures.h”
#include “events/EventQueue.h”
// Application helpers
#include “trace_helper.h”
#include “lora_radio_helper.h”
using namespace events;
// Max payload size can be LORAMAC_PHY_MAXPAYLOAD.
// This example only communicates with much shorter messages (<30 bytes).
// If longer messages are used, these buffers must be changed accordingly.
uint8_t tx_buffer[30];
uint8_t rx_buffer[30];
- Sets up an application dependent transmission timer in ms. Used only when Duty Cycling is off for testing
#define TX_TIMER 10000
- Maximum number of events for the event queue.
- 10 is the safe number for the stack events, however, if application
- also uses the queue for whatever purposes, this number should be increased.
#define MAX_NUMBER_OF_EVENTS 10
- Maximum number of retries for CONFIRMED messages before giving up
#define CONFIRMED_MSG_RETRY_COUNTER 3
- This event queue is the global event queue for both the
- application and stack. To conserve memory, the stack is designed to run
- in the same thread as the application and the application is responsible for
- providing an event queue to the stack that will be used for ISR deferment as
- well as application information event queuing.
static EventQueue ev_queue(MAX_NUMBER_OF_EVENTS *EVENTS_EVENT_SIZE);
- Event handler.
- This will be passed to the LoRaWAN stack to queue events for the
- application which in turn drive the application.
static void lora_event_handler(lorawan_event_t event);
- Constructing Mbed LoRaWANInterface and passing it the radio object from lora_radio_helper.
static LoRaWANInterface lorawan(radio);
- Application specific callbacks
static lorawan_app_callbacks_t callbacks;
Entry point for application
int main(void)
{// setup tracing
setup_trace();// stores the status of a call to LoRaWAN protocol
lorawan_status_t retcode;// Initialize LoRaWAN stack
if (lorawan.initialize(&ev_queue) != LORAWAN_STATUS_OK) {
printf(“\r\n LoRa initialization failed! \r\n”);
return -1;
}printf(“\r\n Mbed LoRaWANStack initialized \r\n”);
// prepare application callbacks
callbacks.events = mbed::callback(lora_event_handler);
lorawan.add_app_callbacks(&callbacks);// Set number of retries in case of CONFIRMED messages
if (lorawan.set_confirmed_msg_retries(CONFIRMED_MSG_RETRY_COUNTER)
printf(“\r\n set_confirmed_msg_retries failed! \r\n\r\n”);
return -1;
}printf(“\r\n CONFIRMED message retries : %d \r\n”,
CONFIRMED_MSG_RETRY_COUNTER);// Enable adaptive data rate
if (lorawan.enable_adaptive_datarate() != LORAWAN_STATUS_OK) {
printf(“\r\n enable_adaptive_datarate failed! \r\n”);
return -1;
}printf(“\r\n Adaptive data rate (ADR) - Enabled \r\n”);
retcode = lorawan.connect();
if (retcode == LORAWAN_STATUS_OK ||
retcode == LORAWAN_STATUS_CONNECT_IN_PROGRESS) {
} else {
printf(“\r\n Connection error, code = %d \r\n”, retcode);
return -1;
}printf(“\r\n Connection - In Progress …\r\n”);
// make your event queue dispatching events forever
ev_queue.dispatch_forever();return 0;
Sends a message to the Network Server
static void send_message(uint8_t Octet_envoye) {static DigitalOut led(LED1, 0);
// create a one-byte payload which contains whether the PIR sensor is high or low
uint8_t buffer1 = {Octet_envoye};
int16_t retcode = lorawan.send(MBED_CONF_LORA_APP_PORT, buffer1, sizeof(buffer1), MSG_CONFIRMED_FLAG);led =1;
ThisThread::sleep_for(500);
led=0;if (retcode != 0) {
printf(“Sent message over LoRaWAN successfully!\n”);}
else {
printf(“Failed to send message (duty-cycle violation?) (%d)\n”, retcode);
Receive a message from the Network Server
static void receive_message() {int16_t retcode = lorawan.receive(MBED_CONF_LORA_APP_PORT, rx_buffer,
LORAMAC_PHY_MAXPAYLOAD,
MSG_CONFIRMED_FLAG|MSG_UNCONFIRMED_FLAG);// ignore errors while retrieving
if (retcode < 0) return;printf(“Received %d bytes: “, retcode);
for (uint8_t i = 0; i < retcode; i++) {
printf(”%x”, rx_buffer[i]);
printf(“\n”);
Event handler
static DigitalOut led2(LED3, 0);
static DigitalOut led3(LED4, 0);
switch (event) {
case CONNECTED:
printf(“\r\n Connection - Successful \r\n”);
if (MBED_CONF_LORA_DUTY_CYCLE_ON) {
send_message(1);} else { ev_queue.call_every(TX_TIMER, send_message,1); } break; case DISCONNECTED: ev_queue.break_dispatch(); printf("\r\n Disconnected Successfully \r\n"); break; case TX_DONE: printf("\r\n Message Sent to Network Server \r\n"); if (MBED_CONF_LORA_DUTY_CYCLE_ON) { send_message(5); ThisThread::sleep_for(5000); send_message(4); ThisThread::sleep_for(5000); send_message(2); ThisThread::sleep_for(5000); send_message(8); ThisThread::sleep_for(5000); send_message(11); ThisThread::sleep_for(5000); send_message(143); ThisThread::sleep_for(5000); send_message(60); led3=1; ThisThread::sleep_for(500); led3=0; } break; case TX_TIMEOUT: case TX_ERROR: case TX_CRYPTO_ERROR: case TX_SCHEDULING_ERROR: printf("\r\n Transmission Error - EventCode = %d \r\n", event); // try again if (MBED_CONF_LORA_DUTY_CYCLE_ON) { send_message(1); } break; case RX_DONE: printf("\r\n Received message from Network Server \r\n"); receive_message(); break; case RX_TIMEOUT: case RX_ERROR: printf("\r\n Error in reception - Code = %d \r\n", event); break; case JOIN_FAILURE: printf("\r\n OTAA Failed - Check Keys \r\n"); break; case UPLINK_REQUIRED: printf("\r\n Uplink required by NS \r\n"); if (MBED_CONF_LORA_DUTY_CYCLE_ON) { send_message(1); } break; default: MBED_ASSERT("Unknown Event");}
// EOF
The code is compiling well, and the 5 seconds was to see if it was a syncro problem with TTN.
Thanks in advance,
Natan
