I am finding that sometimes my webserver works and sometimes it does not. It appears that when it does not work I am getting alert messages. For example here I got:
ssl_tls.c 4253: got an alert message, type: [2:40]
ssl_tls.c 4261: is a fatal alert message (msg 40)
ssl_tls.c 6867: <= handshake
From RFC type 40 is a handshake_failure alert.
I also get other types:
ssl_tls.c 4253: got an alert message, type: [2:46]
ssl_tls.c 4261: is a fatal alert message (msg 46)
ERROR: altcp_tls_mbedtls.c 283: mbedtls_ssl_handshake failed: -0x7780
46 is a certificate_unknown failure.
My question is why does it work sometimes and others not?
Note I have tried 2.16.4 and 2.7.13 versions of mbedtls and both are behaving the same. I am running this on a ATSAME70 with 384k of SRAM, with LWIP. My configuration is below. The SAME70 has a hardware random number generator which I use for the entropy. I do not have the time enabled on the device, maybe this is the problem?
I generated the certificate using openssl using the following commands:
openssl ecparam -genkey -name prime256v1 -out ca.key
openssl req -x509 -new -SHA256 -nodes -key ca.key -days 3650 -out ca.crt
Thanks
Trampas
- \file config-no-entropy.h
- \brief Minimal configuration of features that do not require an entropy source
/ - Copyright © 2016, ARM Limited, All Rights Reserved
- SPDX-License-Identifier: Apache-2.0
- Licensed under the Apache License, Version 2.0 (the “License”); you may
- not use this file except in compliance with the License.
- You may obtain a copy of the License at
- http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software
- distributed under the License is distributed on an “AS IS” BASIS, WITHOUT
- WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- See the License for the specific language governing permissions and
- limitations under the License.
- This file is part of mbed TLS (https://tls.mbed.org)
/ - Minimal configuration of features that do not require an entropy source
- Distinguishing reatures:
- no entropy module
- no TLS protocol implementation available due to absence of an entropy
- source
- See README.txt for usage instructions.
#ifndef MBEDTLS_CONFIG_H
#define MBEDTLS_CONFIG_H
#include “libraries\syslog\syslog.h”
/* System support */
#define MBEDTLS_HAVE_ASM
//#define MBEDTLS_HAVE_TIME
#define MBEDTLS_SSL_RENEGOTIATION
#define MBEDTLS_KEY_EXCHANGE__WITH_CERT__ENABLED
#define MBEDTLS_SSL_FALLBACK_SCSV
#define MBEDTLS_SSL_CACHE_DEFAULT_MAX_ENTRIES 4
#define MBEDTLS_ENTROPY_C
#define MBEDTLS_CTR_DRBG_C
#define MBEDTLS_SSL_TLS_C
//#define MBEDTLS_SSL_CLI_C
#define MBEDTLS_SSL_SRV_C
#define MBEDTLS_ECDH_C
#define MBEDTLS_ECDSA_C
#define MBEDTLS_ECP_C
#define MBEDTLS_CMAC_C
//#define MBEDTLS_NO_PLATFORM_ENTROPY
//#define MBEDTLS_SSL_PROTO_TLS1
//#define MBEDTLS_SSL_PROTO_SSL3
//#define MBEDTLS_SSL_PROTO_TLS1_1
#define MBEDTLS_SSL_PROTO_TLS1_2
/* mbed TLS feature support */
#define MBEDTLS_CIPHER_MODE_CBC
#define MBEDTLS_CIPHER_PADDING_PKCS7
#define MBEDTLS_REMOVE_ARC4_CIPHERSUITES
#define MBEDTLS_ECP_DP_SECP256R1_ENABLED
#define MBEDTLS_ECP_DP_SECP384R1_ENABLED
#define MBEDTLS_ECP_DP_CURVE25519_ENABLED
#define MBEDTLS_ECP_NIST_OPTIM
#define MBEDTLS_ECDSA_DETERMINISTIC
//#define MBEDTLS_PK_RSA_ALT_SUPPORT
#define MBEDTLS_PKCS1_V15
#define MBEDTLS_PKCS1_V21
#define MBEDTLS_SELF_TEST
#define MBEDTLS_VERSION_FEATURES
#define MBEDTLS_X509_CHECK_KEY_USAGE
#define MBEDTLS_X509_CHECK_EXTENDED_KEY_USAGE
/* mbed TLS modules */
#define MBEDTLS_AES_C
#define MBEDTLS_ASN1_PARSE_C
#define MBEDTLS_ASN1_WRITE_C
#define MBEDTLS_BASE64_C
#define MBEDTLS_BIGNUM_C
#define MBEDTLS_CCM_C
#define MBEDTLS_CIPHER_C
#define MBEDTLS_ERROR_C
#define MBEDTLS_GCM_C
#define MBEDTLS_HMAC_DRBG_C
#define MBEDTLS_MD_C
#define MBEDTLS_OID_C
#define MBEDTLS_PEM_PARSE_C
#define MBEDTLS_PK_C
#define MBEDTLS_PK_PARSE_C
#define MBEDTLS_PK_WRITE_C
#define MBEDTLS_PLATFORM_C
//#define MBEDTLS_RSA_C
#define MBEDTLS_SHA256_C
#define MBEDTLS_SHA512_C
#define MBEDTLS_VERSION_C
#define MBEDTLS_X509_USE_C
#define MBEDTLS_X509_CRT_PARSE_C
#define MBEDTLS_X509_CRL_PARSE_C
//#define MBEDTLS_CMAC_C
#define MBEDTLS_MD5_C
#define MBEDTLS_SHA1_C
/* Miscellaneous options */
#define MBEDTLS_AES_ROM_TABLES
///* System support /
//#define MBEDTLS_HAVE_ASM
/ mbed TLS feature support */
#define MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED
//#define MBEDTLS_KEY_EXCHANGE_RSA_PSK_ENABLED
///* Save RAM at the expense of ROM /
/// Save RAM by adjusting to our exact needs /
//#define MBEDTLS_ECP_MAX_BITS 384
//#define MBEDTLS_MPI_MAX_SIZE 48 // 384 bits is 48 bytes
/// Save RAM at the expense of speed, see ecp.h /
//#define MBEDTLS_ECP_WINDOW_SIZE 2
//#define MBEDTLS_ECP_FIXED_POINT_OPTIM 0
/// Significant speed benefit at the expense of some ROM */
//#define MBEDTLS_ECP_NIST_OPTIM
- You should adjust this to the exact number of sources you’re using: default
- is the “mbedtls_platform_entropy_poll” source, but you may want to add other ones.
- Minimum is 2 for the entropy test suite.
#define MBEDTLS_ENTROPY_MAX_SOURCES 2
/ Save ROM and a few bytes of RAM by specifying our own ciphersuite list */
#define MBEDTLS_SSL_CIPHERSUITES
MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384,
MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
- Save RAM at the expense of interoperability: do this only if you control
- both ends of the connection! (See coments in “mbedtls/ssl.h”.)
- The minimum size here depends on the certificate chain used as well as the
- typical size of records.
#define MBEDTLS_SSL_MAX_CONTENT_LEN 16384
//#define MBEDTLS_SSL_SESSION_TICKETS
//#define MBEDTLS_SSL_ALPN
//#define MBEDTLS_SSL_EXTENDED_MASTER_SECRET
//#define MBEDTLS_SSL_ENCRYPT_THEN_MAC
//#define MBEDTLS_SSL_TRUNCATED_HMAC
//#define MBEDTLS_SSL_MAX_FRAGMENT_LENGTH
////#define MBEDTLS_KEY_EXCHANGE_ECJPAKE_ENABLED
//#define MBEDTLS_SSL_SERVER_NAME_INDICATION
//#define MBEDTLS_SSL_PROTO_DTLS
#include “check_config.h”
#endif /* MBEDTLS_CONFIG_H */
