Hi guys…
Is it possible to set a connect timeout when trying to use device as a central?
I have NRF52840 Dev kit and mbed-os-5.15.2 with "target.features_add": ["BLE"].
The issue that I am currently experiencing is that when there is no device in proximity the connect attempt never times out or at least i am not notified about it. So i tried to use cancelConnect() to stop the connection but instead after it when i turn on the device it connects without me wanting it to.
Is it possible to set connect timeout to 10s?
What do you suggest for alternative solution?
Thanks for your replay.
I connect directly using connect method which for argument takes mac address without scanning although i think that connect internally uses scan to find the device.
